Guess it was Monday or Tuesday I changed the fuel filter.
The next day I had a good startup then it died after a few mins.
It ran out of fuel. Removed fuel filter and nothing flowing into bowl with KO.
Text my friend Jason and get the part number for my wix prefilter. Really need to write it down in my truck.
Swap that because it was funky. Still no flow.
Then end up straight jumping 12v from battery and after four arcs on off the pump starts pumping again.Jumped to make sure it wasn't any relay fuse failure.
Discuss options with Sous and Jason and decide on replacement under my own schedule.
Here is the Bosch part number from NAPA.
Direct identical hookup. Just need to get out of bracket and swap engine side fuel barb.
