Fuel pump replacement
Old Apr 4, 2022 | 09:24 AM
nighthawking's Avatar
nighthawking
1977 391 F750 supposedly.
Finding all kind of different model numbers for fuel pump. Not sure which is correct. Newer one has fuel bowl. Existing one seems simple. Would like to replace with an original type if good idea. Pic shows one removed from engine. Not sure if original.
Old Apr 4, 2022 | 12:15 PM
85e150's Avatar
85e150
You may not have a 391. You don't need to start a new thread on every item.
Old Apr 5, 2022 | 12:06 AM
85e150's Avatar
85e150
OP has 391.
Fuel pump can be had with or without the filter canister. Probably best to get one with the filter if it will fit on your engine -- crossmembers are in the way on pickups, yours should be open below the pump.
All there is to know about the pumps:
https://www.ford-trucks.com/forums/1...l#post20146176
Old Apr 5, 2022 | 06:08 AM
nighthawking
Perfect. Thnx.
Old Apr 5, 2022 | 08:54 AM
DB429SCJ's Avatar
DB429SCJ
From 1978 shop manual:
Phase3
Dec 17, 2023 09:30 PM
Johnny Ryall
Aug 26, 2020 11:41 AM
65f600
Large Truck
Nov 12, 2019 07:14 PM
Yuriy Fomin
18
May 19, 2019 10:40 AM
C350CREW
17
Sep 27, 2010 11:18 AM
