BEST Throttle Cable for EFI?
Old Mar 21, 2024 | 11:31 AM
Jonnys.1991's Avatar
Jonnys.1991
I am needing a Throttle Cable for my 91 F150, 5.0, EFI. The OEM Ford part is # E9TZ9A758L and I can't find it anywhere. I hate to get an After market but if so, I wish to get the best one available. Any suggestions on brand? Thanks, Jon.
Old Mar 21, 2024 | 04:57 PM
Mudsport96's Avatar
Mudsport96
If you can't find one at a dealership, rockauto is a good start. And I doubt at this time you will find a Motorcraft or factory ford cable. Your best bet is probably an aftermarket one.
Old Mar 21, 2024 | 05:52 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I used one from LMC Truck on the Bronco. That was many years ago so I cannot say how they are now.
Old Mar 21, 2024 | 07:08 PM
Junktownbill99's Avatar
Junktownbill99
I just bought a cable, and made a spacer to hold the pedal at the right height, works good for me
Old Mar 22, 2024 | 07:12 PM
My4Fordtrucks
I don’t know that that means. It sounds like something is wrong.
Old Mar 22, 2024 | 11:32 PM
Junktownbill99
I Bought the (37?) inch cable instead of the (42?) inch one (listed for my truck) , it fits and connected everything good, but the actual cable was too long, and the pedal sat too low.
Basically I'm just saying don't be too picky, get a cable, and with maybe a little adjustment, it'll work.
Old Mar 23, 2024 | 04:35 AM
My4Fordtrucks
I think you have the numbers reversed. It sounds like you bought a cable that was too long and then the pedal doesn’t do anything until there is tension on the cable.
Old Mar 23, 2024 | 06:22 AM
Junktownbill99
no. Shorter plastic, longer cable
Old Mar 23, 2024 | 07:04 AM
My4Fordtrucks
The plastic is irrelevant. The clip locks the cable into the gas pedal and the spring on the throttle body end keeps tension on the cable.
Anyway, to the OP, remove and measure your old cable before ordering.
Old Mar 23, 2024 | 08:39 AM
Junktownbill99
Exactly, it doesn't really matter what you get, mine all locks in, but the CABLE is too long, and the pedal sits too far down without a spacer.
Yes, op should measure though. I didn't, but I wasn't going to go through the trouble of returning and buying another cable.
samuel4wolfpack
Sep 2, 2023 10:40 AM
mauicruza
1966 - 1977 Early Broncos
Apr 24, 2008 10:59 AM
RyanMiller
Jan 15, 2006 04:53 PM
ucmeflyby
1978 - 1996 Big Bronco
Sep 11, 2005 10:29 PM
