302 EFI throttle cable
Old Jan 14, 2006 | 02:42 PM
RyanMiller's Avatar
RyanMiller
My throttle cable kept getting jammed up, so I pulled of the black cap, and found that the plastic piece that slides over the cable was cracked, and would get hung up on the cable caesing. I dont see a way to get the plastic piece off the end of the throttle cable without breaking it.
Do I need a whole new throttle cable or what?
this is on a 86, EFI 302.
Old Jan 15, 2006 | 12:48 AM
fordborn's Avatar
fordborn
Thread moved to " 221, 260, 289, 5.0/302, 5.8/351W V8" tech forum.
Old Jan 15, 2006 | 12:40 PM
TigerDan's Avatar
TigerDan
I believe those cable ends are molded onto the cable and I'm pretty sure they're not replaceable. Looks like you'll just have to bit the bullet and spring for a whole new cable.
Old Jan 15, 2006 | 04:53 PM
EPNCSU2006's Avatar
EPNCSU2006
If you don't mind running without cruise control, you can break off the plastic part and just leave the cable with the snap on ring on the end to attach to the throttle body. I've done this and aside from not having cruise control, it is fine. I did add a spring on the throttle body to make up for losing the spring on the end of the cable.
