shocks
Old Mar 20, 2024 | 01:18 PM
elkhart75839's Avatar
elkhart75839
shocks
What are good shocks for my 1982 f150? Bilstien,
monroe or ebay shocks? What do most people use on our bullnose trucks?
Old Mar 20, 2024 | 02:08 PM
Bronco638's Avatar
Bronco638
Bilstein are supposed to be awesome but they're not cheap. Monroe has quite a few options, IIRC. eBay has shocks? I think Rancho and OME make shocks for our trucks, if you go off-road.
I'd prolly go Monroe and chose what fit in my budget.
Old Mar 21, 2024 | 08:02 AM
Yendra Built's Avatar
Yendra Built
I think KYB shocks are of the same type as Bilstein. They have both the monotube shocks and the twin tube available. I use the monotube called the Gas-Adjust some people don't like increased handling feel of them on older vehicles, I love it...
Old Mar 21, 2024 | 09:02 AM
soybomb's Avatar
soybomb
Just put KYB gas adjust on my '86 F250 and immediately noticed the better ride. Granted i was rolling around on the factory shocks until that point and one was leaking like a sieve. I'm 99% on paved surfaces.
Old Mar 22, 2024 | 01:17 AM
K9Kodi's Avatar
K9Kodi
i run fox on the nice truck haha, progressive valving with a lifted progressive coil.
on my bullnose i'll got the rancho n3 i believe. with the coils and ride of the old truck a shock isn't gonna make it better. they look decent and ride well
Old Mar 22, 2024 | 05:15 AM
Olds64's Avatar
Olds64
I tried to install the Monroe 58591 shocks with helper springs in the back of my Bullnose truck. They were the heavy duty version available at the auto parts store. I couldn't get them installed because I couldn't get the suspension of the truck "unsprung" enough to install. So, I installed the Monroe 37038 instead.
Old Mar 22, 2024 | 07:30 PM
FuzzFace2's Avatar
FuzzFace2
I had Rancho's on a 86 K5 full size Blazer and found they were to stiff for the mounts as it broke 2 of them 1 of them twice, ride was fine.
Most if not all factory shock mounts are not made strong enough to support weight like your helper springs on the shocks.
See my post above about mounts.
I am running KYB's from LMC on my 81 F100 4x2 and I think the ride is pretty smooth.
Dave ----
Old Mar 22, 2024 | 08:53 PM
BigBlue2's Avatar
BigBlue2
I'm not sure about shocks with helper springs. Never considered them. The springs on the truck are designed to handle your suspension needs. The shock absorber's job is to damp any oscillation of the suspension. I'm running the OE equivalent Monroe shocks. These are very good on my F250. Neutralizes any bump or pothole to one oscillation. Does an excellent job of stabilizing the ride. Shocks wear out. Consider a new set of shocks with every new set of tires. Typically every 50,000 miles.
Old Mar 23, 2024 | 04:00 AM
FuzzFace2's Avatar
FuzzFace2
Shocks with helper springs and air shocks were a way to help support heavy loads but as said shock mounts are not meant to support weight.
On trucks it may not be to bad but on cars were the upper mount went to sheet metal trunk pan the shock would push thru in no time.
You would see this mostly with air shocks to fit larger tires out back.
WOW every 50K
Then I am way over being on I think my 2nd set or maybe 3rd and have just under 300K on my 02 Dodge
Dave ----
Old Mar 23, 2024 | 08:08 AM
dustyroad's Avatar
dustyroad
I use kyb on my 86 and they seem ok. I would probably buy again.
Old Mar 23, 2024 | 10:26 AM
BigBlue2's Avatar
BigBlue2
WOW every 50K
Dave ----
Hey, if your shocks are still doing a good job of damping then run them. My motto is if it works don't fix it. I think that a new set of tires will wear better with new shocks. Especially front shocks on a F250 HD with a heavy diesel or big block gasser. I also purchased lifetime shocks from my local tire store so I have them replaced for free every time I get a new set of tires. With a lighter truck that doesn't get loaded up or taken off road YMMV.
Irtnog
Mar 23, 2023 11:35 PM
97 F250 Heavy Duty
1997 - 2003 F150
Jul 31, 2007 02:03 PM
wendell borror
Offroad & 4x4
Apr 7, 2006 09:48 AM
jberylecrider
Aug 1, 2002 11:22 AM
