Problem solved
Old Mar 20, 2024 | 05:46 AM
Jamon Norton's Avatar
Jamon Norton
Problem solved
I ended up, figuring out my vibration issue yesterday and break issue all at once. Back in October, I had the rear end, transmission, and driveshaft rebuilt. The truck came back with a slight vibration. Also, at this time I had them replace the backing plate and all hardware for the parking break. When I got the truck back, it had a slight vibration. I added my traction bars, and it still had the slight vibration fast forward to yesterday. The brakes had started making more noise. I had my trailer in tow I pulled into the O’Reillys parking lot to look at it and the brakes locked up to the point of I stalled the truck out. I backed into the parking spot, unhooked the trailer and pulled off the tire and the rotor had split in half on the back passenger side. It ended up being an issue with the rear parking brake was causing my vibration because after I put everything back together minus a parking brake my vibration is gone. I know it keeps coming back for a low contribution on a couple cylinders, but that code just keeps jumping from cylinder to cylinder. The only one that shows up every time is number eight I am almost wondering if that is due to having 200 200 injectors because the truck sure seems to run fine. I’m assuming my fuel mileage will go back up also
The pieces in the middle of the rotor are what’s left of the parking brake. I’m thinking I got a faulty backing plate for the parking brake. Ended up ruining my rear brakes on that side that only had 25k miles on them but less than an hr back on the road
Old Mar 20, 2024 | 08:40 AM
Brother Les's Avatar
Brother Les
I gave up using my 'parking brake (break)' years ago. One day when I used it, it stuck 'on' and would not release. A flat bed tow and visit to the 'shop' cost me way too much to ever use the 'parking brake' again.
Old Mar 20, 2024 | 11:18 AM
Jamon Norton
my truck has a ZF 6 transmission a parking parking brake is very nice
Old Mar 20, 2024 | 12:20 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I would go as far to say on a manual transmission truck it is required to have a functioning parking brake.
A few years ago when I resealed the rear axle and replaced the parking brake hardware, I cut some 1" or so diamonds in the friction material of the parking brake shoes. Now, the parking brake will hold the truck and 5th wheel camper, even on a slight incline.
I am surprised you didn't smell or hear anything from the rear passenger side by the looks of that rotor. Also you are lucky there was not a catastrophic failure at highway speeds.
Old Mar 20, 2024 | 12:44 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Do you have any photos of these 1" diamonds you cut?
Originally Posted by Sous
A few years ago I cut some 1" or so diamonds in the friction material of the parking brake shoes. Now, the parking brake will hold the truck and 5th wheel camper, even on a slight incline.
Old Mar 20, 2024 | 02:46 PM
Bonanza35's Avatar
Bonanza35
Like to see them to! My parking brake has never worked right, even with all new parts.
Old Mar 20, 2024 | 04:36 PM
Tpayne621's Avatar
Tpayne621
I thought about doing the same but doing it to the actual drum inside the rotor. The shoes being a littler softer should dig into the grooves and grab nice and tight. From all the park brake shoes I've tried over the years I get the best results out of Motorcraft ones.
Old Mar 20, 2024 | 06:11 PM
Sous's Avatar
Sous
FTE Emeritus
No sir, I did not take a picture at the time of modification because I was not sure it would work. Although, in 2021 I had a post where I created an illustration for someone else that was wanting details. I have pasted the image below.
Referenced link: https://www.ford-trucks.com/forums/1...l#post19887039
Chet, please see the image above for more details. If you have further questions, I would be glad to answer them if I am able. I too was woefully disappointed in the parking brake, but I NEEDED it to work. I tried this and here we are years later and it is still working well.
Apparently, the Motorcraft rear rotors have a knurled surface on the interior of the hat. I believe that @ESwift verified this for us a while back. I too had thoughts of putting some lines in the rotor, but the thought of changing the balance of the rotating assembly did not sit well with me. The shoes and pads do not move or rotate at all when the vehicle is moving, like the rotors do so I gave it a shot. Years later I have not even had to adjust the shoes even though the parking brake gets used a lot.
If this didn't work, I was going to install a line lock similar to how Eswift did. Thankfully it did and has worked for quite some time. Although, the next time I change the pads or rotors in the rear, I will be getting the Motorcraft rotors with the textured surface just for the added holding power.
Oh ya, I have Motorcraft parking brake shoes/pads as well.
Old Mar 20, 2024 | 09:03 PM
Jamon Norton
definitely need to try this
Old Mar 21, 2024 | 05:08 PM
ESwift's Avatar
ESwift
CNCFAB
yep, last set of motorcraft rear rotors I bought had bead blasted/textured inside where the parking brake shoe is.
I still much prefer the linelock on my zf6 truck.
Old Mar 21, 2024 | 09:35 PM
Jamon Norton
I will have to look into doing a line lock on my zf6 what brakes did you install it to just back, all 4 or fronts so you could also do burnouts😁
Old Mar 22, 2024 | 08:29 AM
Sous's Avatar
Sous
FTE Emeritus
My only issue with the linlock is that it is not a set it and forget it as I understand it. The linelock is only meant to be used short term and not set overnight or for hours on end, as I understand it anyway.
Old Mar 22, 2024 | 08:50 AM
Jamon Norton
that’s fine by me because I’m more looking at wanting to be able to hold the truck while I run in somewhere quickly or have to just get out for a short while also on the boat ramp. When I shut it off I can just stick it in gear.
Old Mar 22, 2024 | 08:56 AM
Sous's Avatar
Sous
FTE Emeritus
Sounds like the linelock is a winner for you then! We look forward to your thoughts on the install and your new method of "holding" the truck in place.
Old Mar 22, 2024 | 10:19 AM
ESwift's Avatar
ESwift
CNCFAB
Some line lock models, like the one on my plow truck, are just for short term holding and they do great. Mico also makes versions that have their own electronics and will sense and adjust the pressure to keep the brakes held for extended periods, those ones are really nice but they are close to $2k I believe.
