LATER AXLES
Old Mar 19, 2024 | 06:00 PM
Rad082625's Avatar
Rad082625
LATER AXLES
On my 1962 f250 4X4 what if any later axles will bolt in my Dana 60 rear and Dana 44 front axles with 4:56 gears with the proper spline count to use lockers or limited slips in both axles
No one makes them for these low spline count axles anymore......Bob
Old Mar 20, 2024 | 11:06 AM
Pickupmanx2's Avatar
Pickupmanx2
Good question I have absolutely no answer for... but I like your truck without seeing it!
Old Mar 20, 2024 | 11:09 AM
Rad082625's Avatar
Rad082625
Just to clarify, I only want to swap the shafts...Bob
Old Apr 3, 2024 | 04:33 PM
napass2004's Avatar
napass2004
So from the little research I have done I’ve found that the rear axle should be fairly easily converted to 30 spline. I have not verified this info but if you swap the axle shaft from a newer axle as well as the side gears in the differential gears. You just verify the length is good on the shafts and they should work theoretically.
Again I have not verified this to be true. Look on the 4x4 forums a lot of Jeep guys are running the converted older Dana 60s
gsiamrod
May 12, 2009 12:47 PM
az old school
Sep 6, 2008 03:50 AM
AirSmitty
Aug 27, 2005 10:33 PM
lee
May 31, 2003 04:01 AM
elliott
Mar 7, 2003 07:37 AM
