Tire Replacement Question
Old Nov 25, 2003 | 08:14 AM
smoker3725's Avatar
smoker3725
Hi Guys,
I have a 2000 Ranger 4x4 off road 4.0 v6. w/ 28k
I do a lot of highway driving, and would like to get a smoother ride and better gas miles without giving up the traction that I need in the winter months.
Any suggestions??
Old Nov 25, 2003 | 03:07 PM
Ken00's Avatar
Ken00
I have heard that Bilstien shocks improve the ride.
Old Nov 25, 2003 | 09:14 PM
Rancha9's Avatar
Rancha9
If you don't do any serious off-roading, a set of all season light truck tires will do just fine, and still work well on the highway. Good thing is, with all the foo-foo "I'm not gonna get my truck dirty by taking it off-road" drivers out there, all-season light truck tires are easy to get ahold of, at a decent price. If you do go off roading a bit, then a set of street biased all terrain tires should do the trick, but they won't ride as nice as the all seasons. Personally, I don't care how it rides on the highway, it's whether it can pull me out of a tight spot off-road 30 miles from anywhere that I count on...
Old Nov 25, 2003 | 10:16 PM
johare's Avatar
johare
Smoker 3725,
I had a similar question a couple of weeks ago and didn't get much response. However I did some research and here is what I found. I drive a "99 Ranger 2wd 4.0L about 100 miles daily on road and wanted a quiet, smooth ride but good wet weather traction. I ended up buying Firestone Destination LEs. They were reasonably priced ($68.00 per for 225x70R15s) and now with about 1000 miles on them I have found them quiet, and providing a smoother ride than my old tires. I have also found that they give very good traction in rain. I haven't had the opportunity to try them in snow yet. So far I am satisfied with my purchase.
Old Nov 28, 2003 | 09:30 PM
vekrause's Avatar
vekrause
Something else to consider...
While researching new tire for my 91 4x4, I found that you don't need tire with the prefix LT (light truck), but rather P (passenger). It has to do with weight rating of the tire. Basically, full size trucks and SUV take light truck tires, a Ranger without the hauling capacity doesn't need them. You get the same size tire, same tread, and there less expensive.
As for tire brands, I went with the Wal-Mart Liberators. From what I could gather they're made by BFG for Wal-Mart. The ride is pretty good, too.
Vince
Old Nov 30, 2003 | 06:54 AM
Bloss Man's Avatar
Bloss Man
I recently put a set of GoodYear 265 -70-16 LT's on my '99 Ranger 4x4. They have an AT tread and they noticably improved the ride and handling over the stock 245's. Don't buy cheap tires. These ran $95 each mounted and balanced at local discount store but it was worth it. The tires are what connect your vehicle to the road!
Old Nov 30, 2003 | 05:55 PM
WXboy's Avatar
WXboy
Bloss Man, which tire did you get? The AT/S? And does it rub at all when you make a turn?
Old Dec 1, 2003 | 05:00 AM
Bloss Man's Avatar
Bloss Man
I have the DESTINATION LE's, a fairly new design-and I meant Firestone, not Goodyear (sorry for the error). They do not rub at all and they are the best truck tires I've owned, and I've owned a lot of them. Going with the larger size adds air volume and does improve the ride. The additional sidewall strength of the LT tires improves the handling. The dealer told me he's sold a number of them to other Ranger owners who wanted an upgrade. The fact is, most stock tires on any new vehicle are El Cheapos unless you're buying a luxury rig.
As soon as you have them installed, get your front end aligned. Also consider aftermarket heavy duty shocks to complete your ride upgrade. You should be able to get a quality set installed for around $300 if you do some price checking.
Old Dec 1, 2003 | 07:45 AM
smoker3725's Avatar
smoker3725
Thanks for all your input!!!
Old Dec 2, 2003 | 11:35 AM
goodbread's Avatar
goodbread
Tires and wheels and ride
I just installed Bilsteins on my 99 XLT 4X2 4dr and they do indeed improve the ride. I live in central NH and need good snow performance. After checking things out I opted for the two-sets-of-wheels solution. The stock 15 inch wheels got Bridgestone Winter Duelers and the Ronal R36 16 inch wheels got G.Y. Eagle LS. I agree with most of the above advice, especially the comments about cheap tires. If you drive on a highway ever, you need first rate tires, regardless of the season.
Old Dec 2, 2003 | 05:46 PM
johare's Avatar
johare
Tirerack sells Firestone Destination LE's (225x70R15) for $63.00 each. Of course you have shipping and installation. I bought a set for my Ranger locally and paid $71.00 each plus tax and installation. My total bill including tax, discard charge for the old tires, mounting, balancing, new stems, road hazard and a front end alignment was $460.00
I have put 2000 miles on the tire now and am very pleased with the ride, noise level, and wet traction (not snow to test snow traction yet).
Old Dec 2, 2003 | 10:39 PM
little feather's Avatar
little feather
I personally use Toyo Tires they are the best, maybe a little more expensive, but your get what you pay for.
Toyo Radial AT for highway driving p24575r16
and TOyo Observes for winter
joeskeeter
Feb 21, 2008 10:23 AM
mikedeason
Apr 2, 2007 10:38 AM
nobull4x4
Jan 23, 2005 03:55 PM
ekers88
Engine Swaps
Jun 24, 2004 09:25 PM
4x4x4x4
Sep 30, 2002 03:55 PM
