Starter Wire Parts Question
Old Mar 18, 2024 | 10:52 AM
nickmac30's Avatar
nickmac30
Does anyone know the part number for the brown/yellow starter wire that connects the starter up to the connection up along the passenger side front fender? I can't find it online. I am only looking to replace it because the metal on the starter end is very brittle. I was also thinking of just splicing in a new connection on that end. Not sure what gauge wire it is off the top of my head. Has anyone done this? Thanks!
Old Mar 18, 2024 | 11:14 AM
udsuth78's Avatar
udsuth78
Are you talking about the signal wire for the starter? A smallish awg wire that connects to the solenoid of the starter with a flat spade type connector? If so I think most folks just make a new one themselves with crimp and solder connectors and wire.
Old Mar 18, 2024 | 11:15 AM
nickmac30's Avatar
nickmac30
yep that is the one I am talking about. Thanks
Old Mar 18, 2024 | 12:21 PM
Tpayne621's Avatar
Tpayne621
I would just Crimp a new end on if it were me. If the rest of the wire is in good shape.
Old Mar 18, 2024 | 01:21 PM
nickmac30's Avatar
nickmac30
Thanks that is likely what I'll do. the connector end is torn but still able to be secured behind the small bolt i have that threads through a post on the starter. I don't want to leave it like that for too long though.
Old Mar 18, 2024 | 01:24 PM
FordTruckNoob's Avatar
FordTruckNoob
Given the age of our trucks, you are probably better off taking the time to replace the entire wire. Also check the contacts of the ignition switch under the steering column.
Old Mar 18, 2024 | 02:09 PM
udsuth78's Avatar
udsuth78
Would you 2 make up my mind already? One says crimp an end, the other says replace it all. Now I'm just confused and torn. Maybe I should just go buy a Dodge. I need more exercise anyway, the walking will do me good.
Old Mar 18, 2024 | 02:34 PM
Tpayne621's Avatar
Tpayne621
Would you 2 make up my mind already? One say crimp an end, the other day replace it all. Now I'm just confused and torn. Maybe I should just go buy a Dodge. I need more exercise anyway, the walking will do me good.
Notice I said if wire was in good shape. lol guess it really depends on where you at in the country. Around me wiring generally doesn't go bad over time.
Old Mar 18, 2024 | 08:09 PM
FordTruckNoob
Nah man. Ridgeline all day.
turbill
28
Feb 28, 2024 08:55 PM
adamkat22
Oct 31, 2012 04:04 PM
captain1997
Aug 23, 2011 10:02 AM
2 stroke man
Jun 11, 2008 09:01 PM
mavman
Jan 17, 2002 08:30 PM
