63 brake cylinders???
Old Nov 25, 2003 | 06:06 AM
bob-63-292's Avatar
bob-63-292
Question 63 brake cylinders???
My front brake cylinders are toast (which explains why my truck would lurch HARD to the right when I braked driving it home from the seller).
But, Ford apparently put wierd cylinders in the 63 - can't find a rebuild kit anywhere.
Does anyone know if the 62 or 64 cylinders fit? Perhaps also changing the master cylinder?
Bob
Old Nov 25, 2003 | 06:22 AM
bob-63-292's Avatar
bob-63-292
Oops. The splendid tech articles mention upgrading to the 1964 backing plate and cylinders... Gotta find a donor.
Bob
Old Nov 25, 2003 | 08:12 AM
bob-63-292's Avatar
bob-63-292
Even better news (at least for me). John's F100 says I can convert a single ended slave cylinder (i.e. front brake cylinders) to dual ended cylinders by simply adding the rods. This would mean I could use a 62 or 64 front brake cylinder instead of hunting down 64 backing plates.
Anyone had any experience doing this?
Bob
Old Nov 25, 2003 | 01:38 PM
BobbyFord's Avatar
BobbyFord
Yes, they actually made two different types, dual anchor and single anchor, depending on consecutive serial number. Both are available from Dennis Carpenter or your local parts store should carry them also. I swapped mine to dual anchor type, now mine stops in reverse, too.
Old Nov 25, 2003 | 06:41 PM
bob-63-292's Avatar
bob-63-292
Put a photo of the old brake cylinder in my gallery. Man, is it nasty.
Bob
Old Nov 25, 2003 | 08:14 PM
james northen's Avatar
james northen
Bob, my truck did the same thing when the brakes were pushed, turned out the flex hoses from the frame to the cylinders were almost swollen closed.
Old Nov 27, 2003 | 08:12 PM
Justoldbobo's Avatar
Justoldbobo
Same with my pick up hoses bad.
Ams1069
Large Truck
Jun 2, 2015 11:58 PM
Fordtruck51
1961 - 1963 F100 Unibody
Apr 29, 2012 10:46 PM
63beater
May 24, 2009 09:21 PM
Bob Crain
Jul 5, 2004 07:15 AM
bob-63-292
Oil & Lubrication
Dec 6, 2003 04:14 AM
