HEAVY load........
Old Mar 16, 2024 | 09:39 AM
OX2's Avatar
OX2
HEAVY load........
Not really, but did pick up a new Toy.
"blew" (or at least belt shifted) two trailer tires, towing 4K lbs on a 14k trailer. Have to love Chinese trailer tire crap.
Never seen one that wasn't worn down to the "cords", have the strands just push themselves out of the tread.
(see pic below)
I switched to BFG Commercial LT's on my deck over. Going to do the same on this one.
Old Mar 16, 2024 | 09:42 AM
Poncho450's Avatar
Poncho450
No matter the quality or expense of trailer it seems that most come with Chicom tires these days.
Old Mar 16, 2024 | 10:00 AM
WE3ZS's Avatar
WE3ZS
Yeah, I don’t understand how the Federal DOT can continue to allow these crappy Chinese ST tires to be imported and sold here. Absolute crap. How old were they? Our TT came with similar ST tires and failed with slipped belts (2 out of 4) in 1.75 years while operating under their load rating. I upgraded to another, but very different Chinese made tire, Sailun S637s, an all steel load range G 16”. Now have about 65 K towing miles on the Sailuns with zero issues. Those BFG commercial tires are also very good!
Old Mar 16, 2024 | 10:09 AM
WE3ZS's Avatar
WE3ZS
At least now some of the better RV manufacturers are mounting good tires at the factory. I think Jayco is using GY Endurance on nearly all trailers and a lot of the larger fifth wheels with 17.5”s that I’ve seen have Coopers on them. But there are still lots of China bombs on new campers too.
Old Mar 16, 2024 | 10:36 AM
scraprat's Avatar
scraprat
Top Answer: 5
I agree about the Sailun tires they seem to be a good quality tire and a G rating on top of it. Me personally would be changing tires immediately if a trailer came with known cheap problematic tires. Less grief than dealing with trailer/ rv repairs from a blowout.
Old Mar 16, 2024 | 11:49 AM
OX2's Avatar
OX2
They were a little over 4 years old, but only about 2K miles. Entire trailer garaged and even jack up trailer so tires hang, when not using it. Highest load ever on it, was 6300 lbs, including weight of trailer.
I'll check out those Sailun's, but pretty sure I'm going with the BFG again (even if the load rating is less, I don't need the full 14K).
Old Mar 16, 2024 | 12:01 PM
Black Buzzard's Avatar
Black Buzzard
I have run cheapest chinese tires on my single axle trailer for 18 years without any issues - maybe 100,000 miles. Trailer is never loaded more than 50% of weight rating and I replace the tires every 2-3 yrs, which is long before the tread is gone.
While my boat trailer with Goodyear tires had sidewall bulges about 6 months after instal.
My 2022F350 blew out rear tire last year on interstate, Goodyear wrangler all terrain.......maybe I hit something?
Not defending chinese tires here, just giving my anecdotal experiences.
Old Mar 16, 2024 | 12:14 PM
bigwin56f100's Avatar
bigwin56f100
I run all my trailer tires at max pressure. Knock on wood it's been 15 plus years since I've had a failure. I run 2 year old tires max on my enclosed trailer then use the tires off the enclosed on my open trailer as it gets a lot of miles and wears them out
Old Mar 16, 2024 | 03:43 PM
senix's Avatar
senix
My dump trailer came with Goodride ST. Made in Thialand.
Doubt they are any better.
Run Goodyear Edurance ST on my 5th wheel.
Both are of 16 inch tires so there are choices.
Old Mar 16, 2024 | 04:49 PM
Joe T's Avatar
Joe T
The Goodrides actually have done ok for me.
Have some from 2018. Put around 1,500-2,000 or so miles a year on them.
I balanced them recently and it rode and handled a tad better.
Old Mar 16, 2024 | 05:05 PM
camperfanatic01's Avatar
camperfanatic01
Yep, it’s one of the reason’s I bought the Jayco we have.
Old Mar 16, 2024 | 08:36 PM
OBS460's Avatar
OBS460
I have over 50k miles on my Cooper H rated tires on my 5th wheel with 50% or more tread left. They wear like iron. Expensive though.
Old Mar 17, 2024 | 05:20 AM
HDGuy23's Avatar
HDGuy23
Maxxis 8008 is what I switch to on my stuff
Old Mar 18, 2024 | 06:33 AM
rufushusky's Avatar
rufushusky
Per capita, Thailand is the world's largest rubber exporter. They are probably better than you think.
Expensive but unlikely to disembowel themselves on the highway. Once the GY's are worn, we will be stepping up to those on my GD 324MBS. Spendy but worth it in the long run.
Old Mar 18, 2024 | 09:19 AM
OBS460's Avatar
OBS460
A better tire than the Cooper is the J-rated Continental HTL2. They are at least $600/tire mounted but will last 100k miles under a 5th wheel.
