Awful Idle
Old Mar 14, 2024 | 01:11 PM
jaybry7.tree's Avatar
jaybry7.tree
4wd Low
Awful Idle
hey yall.. ive had this truck since about the beginning of Novemeber. Ive loved it but the idle is something that has bothered me since i got it. It pulls great and if your into the throttle it has no problem besides a couple hard shifts here and there. but onces its warm it idled really low would lose oil pressure tried to stall all the time. I cleaned the throttle body replaced the air and fuel filter and had to turn the idle up. (Person before me had it all the way screwed out.) After all of that it doesnt idle low anymore but still losses oil pressure at idle compltly and kinda pops in a way. Ive tried eveything i know so hopefully yall know something. It is a 302 with the E40D 4x4. Also has new plugs wires distributer water pump belt radiator.
Old Mar 14, 2024 | 02:35 PM
jas88's Avatar
jas88
Did you clean the IAC valve?
Old Mar 14, 2024 | 02:44 PM
Prototypemech's Avatar
Prototypemech
Loss of oil pressure is concerning. Usually, loss of oil pressure at idle is a sign of a worn-out engine, or maybe just a worn out pump. Put a mechanical oil pressure gauge on it and see what the oil pressure is really doing.
As for the idle problem. Sounds like a vacuum leak. Check all your hoses. Check your vacuum canister for holes. Check your pcv valve. Check your EGR valve to ensure it's not stuck open.
Old Mar 14, 2024 | 03:28 PM
jaybry7.tree
4wd Low
I have not i will clean that thank you
Old Mar 14, 2024 | 03:30 PM
jaybry7.tree
4wd Low
I have found it concerning the second I give it gas its fine I've been contemplating putting a mechanical one in but didn't know if I should. and I have replaced a couple hoses and the canister looks fine. I also don't hear a vacuum leak but I will look for another one and clean those valves
Old Mar 14, 2024 | 11:35 PM
jaybry7.tree
4wd Low
i cleaned them and looked for anymore vaccum leaks they were dirty but i used carb cleaner and there is no vaccum leak.
Old Mar 15, 2024 | 11:59 AM
jaybry7.tree
4wd Low
and it didnt fix it
guitarnik
31
Sep 21, 2008 07:22 PM
vohaul
Dec 14, 2004 08:30 PM
ggnmb
1978 - 1996 Big Bronco
Nov 20, 2004 12:06 PM
paleryder
Sep 30, 2002 12:11 PM
