Rear speaker replacing?
Old Mar 12, 2024 | 03:47 AM
Sparky04SD's Avatar
Sparky04SD
I have looked all over You Tube to find tips on replacing rear speakers. Found stuff on regular and crew cabs but nothing on Supercabs. My 95 in signature does not have screws holding speaker grill on. I need to remove plastic trim panels. What is procedure to remove panels?
Old Mar 12, 2024 | 04:08 AM
sunsmoon's Avatar
sunsmoon
2nd Gear
I did not need to remove the trim to remove the speaker grills. They're relatively flexible metal and held in with a couple tabs. With a bit of care you can flex them and pull them out.
Old Mar 12, 2024 | 12:00 PM
Hit Man X's Avatar
Hit Man X
I removed all mine when I did them last. Gives one a chance to clean back there and add extra sound dampening if chosen.
It is easy to remove anyway.
Old Mar 12, 2024 | 06:18 PM
Sparky04SD's Avatar
Sparky04SD
Are you referring to all the trim when you mention "removed all mine"? And was this on a Supercab?
Old Mar 12, 2024 | 08:14 PM
Hit Man X's Avatar
Hit Man X
Yes, that plastic stuff. It comes out fast.
Yes, extended cab or whatever Ford calls it.
Old Mar 13, 2024 | 12:09 PM
obsxl's Avatar
obsxl
I popped the speaker grills out when I did mine. They come out pretty easy just try not to bend them too much.
evan63
Dec 5, 2021 06:28 PM
jeremiah77
Feb 7, 2015 09:36 PM
toa5150medic
Aug 4, 2010 02:09 PM
Reid lariat
2004 - 2008 F150
16
Dec 24, 2008 09:59 PM
hinten
2004 - 2008 F150
Mar 6, 2006 07:16 PM
