Fiberglass headliner?
Old Mar 11, 2024 | 11:34 AM
Drewski 2's Avatar
Drewski 2
Curious if anyone on here has ever tried making a fiberglass headliner that was pulled from the outer roof skin?
Old Mar 11, 2024 | 03:56 PM
56panelford's Avatar
56panelford
There was a guy here that made his own that way, Can't remember his user name and if my memory hasn't failed me I think he lived in Spain or Portugal. His whole build was incredible. Hopefully someone will remember the fellow if I can't find his thread..
Old Mar 11, 2024 | 05:56 PM
56panelford
Found this Drew https://www.ford-trucks.com/forums/1...ford-f100.html
https://www.ford-trucks.com/forums/member.php?u=678655
Post number 173 is what I remembered, he replaced his roof with a fibreglass panel and used the metal skin as a form..
Old Mar 11, 2024 | 08:27 PM
Drewski 2's Avatar
Drewski 2
Thanks for the info. He did a really nice job on his truck. I got involved in looking at his entire build and didn't really pick up on what he did to form the headliner.
Old Mar 11, 2024 | 08:30 PM
56panelford
I believe he used the inside of the metal roof skin and laid fibreglass cloth then trimmed to fit..
Old Mar 12, 2024 | 04:13 AM
CharlieLed's Avatar
CharlieLed
I made one but it was a mess. The mold release agent that I used did not release and the layup stuck to the roof. I worked around that issue and got a piece the shape of the roof...I knew that it was going to be too big to fit up inside as a headliner so I cut and worked the piece til it fit. The piece took so much work that I stopped working on it and went with an ABS headliner from Midfifty. Looking back on it now, if I were to make another FG headliner, I would cast it off the ABS version...it has the right dimensions and would be easier to handle. I have a ABS headliner in the box if you want to try it out.
Old Mar 12, 2024 | 07:10 AM
Drewski 2's Avatar
Drewski 2
Did you use pva for your release agent? I can see that it would be a rather lengthy and messy task. My top is chopped is the only reason I'm even considering it.
Old Mar 12, 2024 | 09:29 AM
EBEAR's Avatar
EBEAR
I have seen an episode of one of the build shows filling the roof cavity with spay foam of some sort , trimming to shape and then covering .
Old Mar 15, 2024 | 08:18 PM
rhopper's Avatar
rhopper
When I did mine I placed clear plastic over the roof and laid the fiberglass over that. I didn't use a release agent because the plastic didn't stick to the primer on the roof. I made it big enough to be able to trim down for a good fit inside. The front I tucked up above the windshield header Don't forget to run the wire for your overhead light if you're planning to use one. Don't let the resin drip onto the running boards.
Rusty
pdhulteng
Aug 30, 2023 12:43 PM
Lucky513
Feb 24, 2023 05:00 PM
thepitshop
Feb 1, 2019 08:45 PM
Trevor.801
Jun 1, 2014 08:50 PM
DrkPhanstm
May 24, 2002 12:18 AM
