Hard Time Starting
Old Mar 11, 2024 | 02:22 AM
Rutherford_813's Avatar
Rutherford_813
4wd Low
Exclamation Hard Time Starting
Hello, so i purchased a 1990 F250 7.3idi awhile back and I've slowly been working on it but I cannot seem to figure out why it has a hard time starting. I've replaced all the glow plugs and the relay, I know from the previous owner that the injection pump is turned up, probably all the way. I don't know if that would cause it to have a hard time starting or if the pump is just worn. When I plug it in, it starts up every time no issue and runs, never stalls.
Old Mar 11, 2024 | 05:43 AM
Olds64's Avatar
Olds64
What brand glow plugs did you install?
Old Mar 11, 2024 | 03:51 PM
tecgod13's Avatar
tecgod13
I'll second that, sounds like the glow plugs aren't working right.
You only want to use genuine Motorcraft (Beru) plugs. AC Delco are well known to blow and swell up, sometimes after only one use!
There used to be a very good sticky at the top of the forum discussing the glow plug system and how to troubleshoot it, not sure where it went.
Pkupman82
27
Dec 10, 2016 09:59 PM
Mustangfreak
Feb 5, 2009 04:59 PM
farmerf1
May 28, 2008 08:17 PM
Vinford
18
Nov 4, 2007 09:49 AM
Ken aka Savage
Sep 15, 2004 02:01 PM
