Speed off by 1mph
Old Mar 9, 2024 | 07:49 PM
Bad Moose's Avatar
Bad Moose
Sorry, speedo reads 1 mph high. I guess I'll learn to live with it since it is fairly common. I don't think it is worth getting Forscan for the speed issue, now if something else pops up, I'll take the leap.
Thanks for the replies!
Old Mar 9, 2024 | 08:09 PM
00t444e's Avatar
00t444e
Never been in a vehicle that the speedometer is dead on accurate to the GPS, only off by 1 MPH isn't bad at all.
Old Mar 9, 2024 | 10:17 PM
sbechtold's Avatar
sbechtold
I used ForScan to adjust my tire size so that my speedometer and Waze are just about dead on. Yes my OCD won. 😜
Old Mar 9, 2024 | 10:19 PM
Desert Don's Avatar
Desert Don
Originally Posted by Bad Moose
Ok, here it is and it drives me nuts. My 2024 speedo is off by 1 mph as compared to gps speed from Waze, Google maps, Apple maps, or speedometer apps. This truck has just over 5000 miles on it.
The odd thing is that my 2020 was the same way, I though it was tires and when I replaced tires it was the same result.
Interesting but what is the cure to make them match?
The cure is to throw the GPS out the window, and pay attention to the road.
So who says the gps is correct. Up in SE Montana there is a road named “Bay Horse creek road”…..that is what the sign says. I have yet to see a gps get it right. On GPS it is named everything from “Bowers Creek road” to “Bayers creek road” to “Bears creek road” to God only know what.
I had a neighbor that had to put a sign up in his driveway stating “Turn around dumbarse, your GPS is wrong” because lost people were driving into his yard all hours of the day or night.
Old Mar 10, 2024 | 12:48 AM
Quad Racer's Avatar
Quad Racer
The things people have time for.
Old Mar 10, 2024 | 05:50 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Originally Posted by Bugzilla46310
Either slow down or speed up until they match.
OK, I laughed a little at this one...
Old Mar 10, 2024 | 08:49 AM
Bumble2019's Avatar
Bumble2019
Veteran: Navy
As an Old Wind Mill Tilter myself …. I applaud your tenacity!
Old Mar 10, 2024 | 09:22 AM
nitebreeze's Avatar
nitebreeze
Go up one inch larger tire diameter and it usually zeros out the speedometer and it will be correct.
Old Mar 10, 2024 | 09:33 AM
GAZZILLA's Avatar
GAZZILLA
Most people out here drive the two lane highways at the speed limit. There’s no need to pass anyone and no one holds anyone up that way. Nice and safe! An accurate speedometer is needed to set the cruise control at the speed limit.
Old Mar 10, 2024 | 10:24 AM
acadianbob's Avatar
acadianbob
As your tires wear, it's going to get worse!! I'd start worrying about it NOW.
Old Mar 10, 2024 | 10:56 AM
BOSS 379's Avatar
BOSS 379
I recall Motor Trend car reviews in the 80s and 90s had all the tech specs about the car, including speedometer error. It’s the nature of the beast.
Old Mar 10, 2024 | 07:13 PM
B-ManFX4's Avatar
B-ManFX4
And that has exactly what to do with speed calculation via a GPS?
Old Mar 10, 2024 | 07:18 PM
  #28
aquanaut20's Avatar
aquanaut20
Now I am inclined to go check my GPS again.. !!!
Old Mar 10, 2024 | 10:05 PM
  #29
bigwin56f100's Avatar
bigwin56f100
Gosh I hope the tachometer isn't off a couple RPMs too.
Old Mar 10, 2024 | 10:37 PM
  #30
Desert Don's Avatar
Desert Don
absolutely nothing…….except to point out that a gps can be WRONG!!!!!!!! But nope, that is impossible, huh!
