Grinding in reverse
Old Mar 8, 2024 | 04:30 AM
JCStenholm's Avatar
JCStenholm
2nd Gear
Grinding in reverse
Recently bought a 93 F150 4.9L with an auto transmission. Recently when I put it in reverse it sounds like the gears are grinding and gets worse while it sits in reverse and isn’t so bad while moving. Anybody had this issue before and know what the cause is?
Old Mar 8, 2024 | 09:12 AM
jas88's Avatar
jas88
Have you checked the fluid level?
Old Mar 8, 2024 | 03:13 PM
AuroraGirl's Avatar
AuroraGirl
What does your transmission do when it reverses, can you go under it and have someone else put it in reverse with pedal on brake? the transmission might be really wobbling about. Is this a 2wd?
JCStenholm
Mar 8, 2024 08:14 PM
asterof
1997 - 2003 F150
Nov 12, 2023 02:50 PM
Frank79
Jun 18, 2021 05:40 PM
wevie
Feb 2, 2014 10:24 PM
Rockafella
Feb 15, 2003 09:09 PM
