EGR delete.....again
Old Mar 7, 2024 | 07:41 PM
Golden1991's Avatar
Golden1991
I've searched the forum for hours and I can't seem to find a thread that answers my specific situation.
I'm attaching a photo of the valve assembly on the right side by the coil.
The only connection is a y-connector going to a single vacuum hose.
I've got the transmission out right now so I'm looking at the plumbing and wondering if I can just delete the piping and the valves since there is no sensor connected.
One line returns to the EGR I think and that is the only sensor in the whole loop.
I guess the main question is whether there is any value to either leave it or delete it?
This is a 1991 F250 with a 5.8.
Old Mar 7, 2024 | 08:11 PM
rla2005's Avatar
rla2005
That is for the air injection system, not the EGR.
Old Mar 7, 2024 | 09:11 PM
Golden1991's Avatar
Golden1991
It has a line going to the EGR so it's tied into it.
It's a mess of pipes and valves that seem to just dump into the catalytic converter.....just wondered if it's necessary or some EPA nonsense
Old Mar 7, 2024 | 09:41 PM
sswari's Avatar
sswari
Yes, it is part of the emissions control system. Yes, unless you have a way to tune the ECM it is best to leave it in. Sadly, It is not even close to the same as the one on my 5.8 so can't be much help as to hooking it up correctly.
Maybe there is something on youtube, or even check https://www.f150forum.com/f10/
Old Mar 7, 2024 | 09:43 PM
rla2005's Avatar
rla2005
The only tie in is a vacuum supply. No other interaction for two different functions.
Some will say you can eliminate the air injection system with no issues. I tend to agree. If you have to pass a visual inspection obviously the can of worms has to stay.
Old Mar 7, 2024 | 11:28 PM
Soup bean's Avatar
Soup bean
Those parts have value if you decide not to put them back on your engine.
I bought a diverter valve from a member of this forum when I was putting my '88 5.0 back to it's original configuration.
In Maryland, my year truck doesn't get emissions tested but the parts need to be "present" for mechanical inspection, so I figured they might as well be functional.
The air injection system directs the air from the air pump either out of the system, into the exhaust upstream of the catalytic converter or into the tube at the catalytic converter; on my engine.
Old Mar 8, 2024 | 05:23 AM
manicmechanic007's Avatar
manicmechanic007
Here is some worms
We all breathe the same air
Leave all of that on there and make sure it works
Old Mar 8, 2024 | 06:10 AM
My4Fordtrucks's Avatar
My4Fordtrucks
No. The only thing those two systems share is a vacuum source.
Correct. The air injection system dumps air into the converter to help it get up to operating temperature quicker. It is necessary for the converter and it was a result of government regulations.
Old Mar 8, 2024 | 07:22 AM
mackendw's Avatar
mackendw
but it's 100% AOK for the worlds largest polluter to spew particulates non-stop 24X7 into the atmosphere....we all know who that is.
Old Mar 8, 2024 | 08:02 PM
Golden1991's Avatar
Golden1991
Well......after looking at it and the work involved with the possibilities of high idle problems etc....
I'm leaving it.....until it pukes
4.9LOldFordTruck
Dec 22, 2015 02:38 PM
gerk3
Dec 13, 2014 11:52 AM
Chiver
1983 - 2012 Ranger & B-Series
37
Jun 24, 2014 10:34 AM
prerunner
4 Cylinder Engines
Apr 5, 2006 06:29 AM
Mountaineer Boy
Jul 12, 2005 04:12 PM
