Reverse lights?
Old Mar 5, 2024 | 01:03 AM
jays 72 f250's Avatar
jays 72 f250
Trailering
Reverse lights?
Hey y’all does anyone know what color wire under the dash goes to the reverse lights , I have a 72 f250 c/s that had a utility box when I bought it I have since tracked down a color matching bed. Everything except the reverse lights work any info helps.
Old Mar 5, 2024 | 02:38 AM
RTT's Avatar
RTT
Smile
...BK/R FROM BACK-UP SWITCH---CIRCUIT 140B
BROWN FROM TAIL-LIGHT---CIRCUIT 285---
Old Mar 5, 2024 | 11:14 AM
Green72F250's Avatar
Green72F250
Here are some of the 1972 wiring diagrams, you can look at all the wiring diagrams here:
Ford Truck Technical Drawings and Schematics - Section H - Wiring Diagrams (fordification.com)
Old Mar 8, 2024 | 10:56 PM
RTT's Avatar
RTT
I did my looking on my 1971 diagram in a hurry & got one wire kolur' wrong...
The 285 brown is wrong info . 285 is a tail or brake lamp.......
Ok........find the back up switch , my shifter hits it on the column . Trace the wire to the dash........
Find the back-up lamp & trace the black with red stripe wire to the dash ......... BRILLIANT........
Old Mar 10, 2024 | 11:50 AM
jays 72 f250
Trailering
Thank you was able to get them working
Old Mar 10, 2024 | 12:45 PM
1browski's Avatar
1browski
What was wrong with them and how did you fix them? In case someone has the same issue.
Old Mar 10, 2024 | 10:56 PM
jays 72 f250
Trailering
One I wired them onto a switch panel I had under the dash and had a issue with them grounding so to help I pulled the inner light housing out and added a small washer behind them and no problems after that
drivefaster35
Feb 24, 2022 08:14 PM
Bigdaddy77
Nov 3, 2021 06:35 AM
ssande
Jun 22, 2017 10:20 AM
AllieStephs
Sep 11, 2011 02:04 AM
GrampsHandMeDown
2004 - 2008 F150
Dec 27, 2008 10:49 AM
