I have a 1997 460 stroker just getting all put together.. The transmission controller tan wire says speed out. Is where it goes
So I tried 2 separate wires gray black vss speed out didn't work
Tried white purple didn't work. Oh these wires are tight behind the speedo dash. Just read something about vss connection behind the glove box. The reason I have to do this is because I installed a Holley sniper so I need a controller.
Ken
It might be something that you have to turn on and configured in the software. I have the Bauman controller on my truck and that's how it works. I had to tell it the number of pulses per mile or something to that effect..
