Sponsored by: Real Truck
Trans flush questions.
Old Mar 4, 2024 | 07:49 AM
Clover_SD's Avatar
Clover_SD
I have a 2011 F250 SD 6.2 gas with 160k on it. As far as I know there has never been a transmission flush or fluid change on it. I know how to do the job but since I don’t think it’s ever been done I have a few questions.
Should I pull the grill off and drain the trans cooler as well? I’m planning to.
A fully drained system is 17 qts?
Any preference on filter brand?
was thinking of going Royal Purple instead of the Motorcraft VF. Thoughts?
Any other advice/recommendations?
Thanks
Wade
Old Mar 5, 2024 | 04:43 PM
F2shiitty's Avatar
F2shiitty
I serviced my trans on my 13’ 6.2L after noticing a small leak developing around the pan. I dropped the pan replaced the gasket as well as a new filter, gave it a good cleaning and cleaned the magnet while it was open. After it was completely drained and cleaned up and re torqued to spec, as per manual using mercon lv initial fill is 8qts, run it, cycle through all the gears and hold on each of 30ish seconds. After take readings, then at operational temp, add as needed without exceeding the dipstick level as mercon lv expands. I’d recommend using what Ford recommended.also forgot to say, I went to my local dealer, gasket and filter were less than 100$ however the gasket was the last one in my area instock. I think it says you can clean the gasket and re use it but since mine had been leaking I swapped it.
Old Apr 9, 2024 | 04:31 PM
DaveNTx's Avatar
DaveNTx
Originally Posted by F2shiitty
I serviced my trans on my 13’ 6.2L after noticing a small leak developing around the pan. I dropped the pan replaced the gasket as well as a new filter, gave it a good cleaning and cleaned the magnet while it was open.... .
'Quick question : is this a fluid filter or is it a screen? Thanx.
Old Apr 9, 2024 | 07:16 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It is a filter.
toymaster
Sep 7, 2019 11:57 PM
RickBraden
Michigan Chapter
Jun 13, 2012 11:09 PM
007sniper
Jun 21, 2008 05:25 PM
lawnspecialties
May 18, 2006 08:17 AM
Peganit
Aerostar
Feb 13, 2004 12:36 AM
