distribution chain which brand
Old Mar 4, 2024 | 12:23 PM
Nonofordf150's Avatar
Nonofordf150
Ok, thanks for your advice.
Old Mar 5, 2024 | 06:30 AM
Nonofordf150
I want to replace my balancer at the same time the reference is e4tea3a but I cannot find this reference on rockauto, has the number been replaced?
Old Mar 5, 2024 | 11:32 AM
Hit Man X's Avatar
Hit Man X
Did the balancer delaminate? Pretty much all aftermarket are junk now unless you step up to an SFI approved unit. You can mail your old unit out to be rebuilt, I just had the one for my 4.9 rebuilt at Damper Doctor.
Old Mar 5, 2024 | 12:29 PM
Nonofordf150
the rubber is damaged I wanted the part since everything is dismantled
Old Mar 12, 2024 | 01:41 PM
Nonofordf150
Good morning
I received all my parts, could anyone give me the tightening torque of the camshaft sprocket screw, and should I put some (light) joint compound on the gaskets of the distribution cover, the water pump and the plate which screws onto the water pump for safety?
THANK YOU.
Old Mar 12, 2024 | 06:22 PM
Anonymous12's Avatar
Anonymous12
Originally Posted by Nonofordf150
Good morning
THANK YOU.
I believe it’s 40-45 lb ft. I would personally use some light gasket sealer. Make sure you put anti seize on the shank of the timing cover and water pump bolts!!! It’s a real pain to cut the timing cover off of those bolts if they seize in there.
https://www.amazon.com/Permatex-80062-High-Gasket-Sealant/dp/B000HBGHB8/ref=asc_df_B000HBGHB8/?adgrpid=61941536837&gclid=Cj0KCQjw-r-vBhC-ARIsAGgUO2ClkhVvOBYJgZsZR_aia94IE9bhZ3IurUaxE0dSHt KCZumccE5DhDEaAjoTEALw_wcB&hvadid=312141533517&hvd ev=m&hvdvcmdl&hvlocint&hvlocphy=9031508&hvnetw=g&h vpone&hvpos&hvptwo&hvqmt&hvrand=304270542114828258 3&hvtargid=pla-569360552130&linkCode=df0&mcid=f98779f6e10632ab882 8ba63f3d089ed&psc=1&ref&tag
I personally like this stuff.
Old Mar 13, 2024 | 07:09 AM
Nonofordf150
great, thank you
Old Mar 16, 2024 | 06:29 AM
Nonofordf150
Good morning
everything is reassembled however I replaced my fan clutch for safety, with a Hayden but I find that they are slightly engaged while driving and idling, the car warms up well to M and comes back, I would like to have some feedback , if this is normal?
Old Mar 16, 2024 | 06:48 AM
charlie g's Avatar
charlie g
FTE Community Team
NORMAL!!! warmer they get faster they spin .
Old Mar 16, 2024 | 07:03 AM
Nonofordf150
it works thanks
because my old one I only heard it when it was hot, whereas I hear it all the time and it's even louder when it gets hot.
It’s probably a heavy range, is that on purpose?
There is no risk ?
Doesn't this interfere with adjusting my timing?
Old Mar 16, 2024 | 07:06 AM
charlie g's Avatar
charlie g
FTE Community Team
stop worrying. and NO it doesn't affect ignition timing.
Old Mar 16, 2024 | 07:09 AM
Nonofordf150
super thank you, you are on top 👍
Chips2000
May 14, 2021 08:42 PM
46069dord
Jul 19, 2008 11:59 PM
68bluebeast
15
Mar 18, 2007 09:58 PM
lmadore
Aug 8, 2005 01:28 PM
ExcellentRed
Jul 28, 2004 09:42 AM
