93 e350 5.8 PROBLEMS. HELP!!!!!
Old Feb 29, 2024 | 09:54 PM
kristianr72's Avatar
kristianr72
2nd Gear
Exclamation 93 e350 5.8 PROBLEMS. HELP!!!!!
I rebuilt the 5.8l 351 windsor engine from a van i bought since the rings were siezed. got it all put back in and at first it ran but was rough then after shutting it off it wouldnt start back up and would flood plugs. changed the idle air control valve and map sensor. still ran rough and wouldnt start after shutting off, so changed out the fuel pressure regulator and it started right up and ran beautifully but after shutting off it wouldnt start back up. looked up this issue and found out about the coolant temp sensor so i changed that out and now it wont start. it will for a second if you crank with gas pedal to the floor but then shuts off. Really need help with this as i feel like im chasing my tail.
Old Mar 1, 2024 | 04:00 AM
manicmechanic007's Avatar
manicmechanic007
Check the codes, check the fuel pressure
Have that pressure gauge taped to the windshield when you go to start it next time
Rebuilt motors are tight
Next time you get it running, let it run long enough to get real hot before shutting it off
Then give it a rest to cool down before trying it again
After a few of those warm up cycles, the engine should start running better and start easier
That is provided everything is okay including the base timing set
Trust your work
Did you set the base timing?
Old Mar 1, 2024 | 04:42 PM
maples01's Avatar
maples01
Put a carb on it and ditch the EFI.
Old Mar 1, 2024 | 05:06 PM
kristianr72
2nd Gear
Update i retarded the distributer timing and it started. idled for 25 minutes then i shut off to cool down and will try to start again later,
Old Mar 1, 2024 | 07:44 PM
maples01's Avatar
maples01
A computer controlled six has to be 10 degrees before top dead center or it won't run right.
Old Mar 2, 2024 | 06:04 AM
manicmechanic007
Retarded and running is s start
Time it with a light and the spout plug out
Very important to do that First
Borrow a light from a parts store
Lando25
Nov 30, 2023 06:28 PM
ridetrains
56
Nov 10, 2021 11:51 PM
RadioControlGuy85
Feb 2, 2017 10:17 AM
mgd4me_
Jul 11, 2015 09:46 AM
awsmev
1983 - 2012 Ranger & B-Series
Feb 21, 2011 07:01 PM
