Air Bag Lines
Old Mar 3, 2024 | 08:02 PM
jbwardfamily's Avatar
jbwardfamily
Ended up connecting the 2 bags with a Tee and ran the one air line into the gas cap area. I like how it turned out. The plastic piece that should go there with the rubber seal will eventually be modified to go back in, but I can't see what the purpose of that piece is anyway.
Old Mar 3, 2024 | 08:08 PM
Rwhjr's Avatar
Rwhjr
Originally Posted by scraprat
I installed Firestone bags on the '16' dually a few weeks ago and had the fill ports at the rear of the truck but after hooking up the 5th wheel and having to adjust the bags manually decided to go with Airlift Wireless One compressor system (25980). Just need the weather to calm down a bit and I'll get it installed next couplle days. That should make it easier or more convenient for adjustments.
wise choice going with a compressor system
Old Mar 3, 2024 | 11:48 PM
bentring's Avatar
bentring
Our truck came with the airbag lines acting as the license plate attachment but really like the idea of adjusting from cab. I wonder if the horn compressor could be used for both...
Old Mar 4, 2024 | 01:09 PM
four4x4fords's Avatar
four4x4fords
Yes it can, I did it on my 01 F-350. I used the air horn air tank as well. Much slower than a "real" compressor, but it worked fine.
Bonus was the horn compressor fit under the hood.
Old Mar 4, 2024 | 08:34 PM
bentring's Avatar
bentring
Thanks! I've thought of rerouting them somewhere else because it's annoying if I load the camper without checking because the basement blocks them...
Old Mar 4, 2024 | 09:07 PM
chas111's Avatar
chas111
I had RideRite on my 2016 F250 crew cab and inflated to 20psi (empty). I’ve installed AirLift on my 2024 F250 crew cab. What psi are you using with AirLift? I regularly pull a 5th wheel.
Old Mar 5, 2024 | 11:11 AM
four4x4fords
I sold the truck with OBA, and have not got around to installing OBA on my 21, so these numbers are from my experience with my 01 SD
I have a 30’ bumper pull toyhauler. If I am bringing ATVs I ran about 30 psi in the bags. Without toys, about 40-50psi.
Best part of OBA is I can adjust on the fly and fine tune it as I go. My 01 was leveled and OBA and air bags always ensured my rig sat level, no matter the load!
sgthawkusmc
Feb 7, 2022 06:13 PM
77f250400
Dec 17, 2010 02:19 PM
weldboy
Nov 29, 2005 02:20 PM
