OBA Air lines
Old Feb 7, 2022 | 07:39 AM
sgthawkusmc's Avatar
sgthawkusmc
OBA Air lines
All I'm finding are 1/4" OD plastic air lines. That and stainless or AN which seems a little overboard. Are 1/4" OD lines what everyone is using for there onboard air systems?
Old Feb 7, 2022 | 10:13 AM
Rich1961's Avatar
Rich1961
I'm using 3/8" air lines. 3/8" air lines are available at NAPA Auto Parts( and others), ask for truck air brake air lines.
Old Feb 7, 2022 | 11:07 AM
HRTKD's Avatar
HRTKD
Please change the font color you post with. It's hard to read the light grey.
1/4" plastic air lines are what is used for the on-board air in my toy hauler. The OEM plastic lasted 14 years before I replaced it due to leaks, but I don't know how often the air compressor was actually used before I became the third owner.
Old Feb 7, 2022 | 11:48 AM
chadstickpoindexter's Avatar
chadstickpoindexter
This is what I am using. I just installed it about a month ago, and I encapsulated it with wire loom to help protect it. It installed as expected, and I see no reason it won’t last for a long time, but at this point that is just a guess.
Old Feb 7, 2022 | 12:34 PM
TB250's Avatar
TB250
McMaster has multiple sizes of DOT approved plastic tubing:
https://www.mcmaster.com/tubing/plas...ubing-for-air/
As well as push to connect fittings:
https://www.mcmaster.com/fittings/co...tings-for-air/
They also have less expensive Nylon and Polyurethane tubing that is not DOT approved, but I figure the approval and low temperature certifications are cheap insurance.
Old Feb 7, 2022 | 06:13 PM
sgthawkusmc
Thanks. I ordered 3/8" w/ 1/4" npt fittings. Where I went wrong is I was thinking about the thread not the tubing size...
ford2go
Garage & Workshop
13
Jul 27, 2009 01:33 PM
jw miller
Jun 22, 2007 07:09 AM
f150_514ci
Offroad & 4x4
Sep 29, 2004 04:23 PM
Phreetogo
Jul 17, 2003 07:07 PM
