Zero compression on cylinder 6
Old Feb 29, 2024 | 06:58 PM
Old Guy F-250's Avatar
Old Guy F-250
Well the way I read all this, in my opinion Bronco638 gave you the best advice so far. It is a pretty simple test to do.
Like he said, you will be able to hear where the air is coming out. either the ehhaust, carb, or oil breather,
Old Mar 1, 2024 | 07:46 AM
Bronco638's Avatar
Bronco638
Originally Posted by Dcurre1
I was thinking about getting a borescope and taking a look. I’ve been driving the truck for over a month since the massive backfire including long distance trips to San Diego and San Francisco. Not sure if that helps with diagnosis.
Obviously it's not that bad if you've been able to take long trips without catastrophic failure. I'll bet the fuel economy wasn't that great (with essentially a dead cylinder).
If you want to spend money on a borescope, that's cool, they're neat to have. However, it may not be able to show you a burned valve or a bad seat or wasted rings. Then, you'll be back at Square One.
Old Mar 14, 2024 | 02:00 PM
Old Guy F-250
Hey Dcurre1
We never heard back as to what the outcome was.
Did you do a leakdown test
Did you pull the head,
Did you find the problem and fix it
Or are you still driving around on 5 cyls.
It is always nice to read the follow up as to what the problem was others later on will maybe have an idea what to look for..
Old Mar 14, 2024 | 05:35 PM
Dcurre1's Avatar
Dcurre1
Doing some work today on it. About to pull the head. My mechanic has a rebuilt 302 and an old torn down 300 so now I have a couple options. If the price is right I’m considering the 302. Will update you soon.
Old Mar 15, 2024 | 11:09 AM
AbandonedBronco's Avatar
AbandonedBronco
Are these photos from your engine after the backfire that still had compression?
I totally missed this question.
No, sorry. I reread my post and could see how that was confusing.
I had damaged rings from the timing being too far advanced. It was firing while the piston was still going up. Quite a bit of damage, but I still had a small amount of compression.
The pictures I supplied were just examples of what it takes to have zero compression. If all of the parts are moving as they should, and your compression is zero, there's more than likely a hole it's going out of.
Marinemt3521
Feb 24, 2020 12:04 AM
bkuuz1
May 4, 2015 08:45 PM
BroncoBilt
1978 - 1996 Big Bronco
Jan 9, 2015 12:01 PM
nickydobbs
Sep 17, 2014 11:58 PM
VONxRUBENxLA
Jun 20, 2011 08:12 PM
