Help
Old Feb 27, 2024 | 08:42 PM
Havok12's Avatar
Havok12
1st Gear
Help
I have a 99 f350 7.3l 4x4 auto. It's starts up I can move the shifter in to any gear.but will not move on its own power. If I let go of the brake (while it's in gear) it rolls like it in neutral. Please help. I have no idea.
Old Feb 28, 2024 | 12:23 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Are you sure it is going into gear at the trans? Or are you just assuming it is in gear because the indicator says it's in gear?
Is this like an overnight issues or is it something that progressively got to this point? The more back story you provide the better the responses you'll get.
Old Feb 28, 2024 | 01:51 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Is it blowing white smoke out the exhaust?
And yes, please give more info to go on. Maybe post up a video?
Old Feb 28, 2024 | 03:11 AM
udsuth78's Avatar
udsuth78
What the level and condition of the transmission fluid? Does it behave the same if the transfer case is in 4wd?
Old Feb 28, 2024 | 06:39 AM
Rot Box 2's Avatar
Rot Box 2
My E99 lost/wore out a range fork in my transfer case recently… same issue as it popped itself into neutral would not move under its own power.
Not saying that what your issue is just something to think about.
Good luck lots of knowledge here hopefully you can get it sorted.
Old Feb 28, 2024 | 07:26 AM
RacinJasonWV's Avatar
RacinJasonWV
I agree.
1- check transfer case
2- check ATV level (running, in park, flat ground)
3- check shifter cable is actually connected and moving the link of transmission.
4- making any strange sounds?
Old Feb 28, 2024 | 01:36 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
When in park will it roll, or does park hold it?
James Bennett
Mar 12, 2023 01:43 PM
Spode
Dec 13, 2017 10:17 PM
sinwagon
Oct 31, 2015 01:38 PM
M.Rad.
Feb 18, 2014 09:09 PM
