Bad fuel sending unit? Help please
#76
#77
I was going back through things and this picture caught my eye. I've circled the exposed ferule because I'm confused as to why it's that color. I'm assuming the fitting is stainless steel but I'm questioning whether that ferule actually is. The trick about SS is that it is in fact stainless, the name kinda gives it away. So if it is SS what the hell has been in that tank that will turn SS that color? If it isn't SS then what the hell is it?
The other thing I circled is some discoloration on the tube. It could just be from when the level gauge was spot welded to the tube, but I remembered you were getting some odd behavior from the gauge cluster. So could be a short that's been arcing to the tube there. Worth a look anyway.
I also see rust or corrosion on the level gauge bracket. That brings us back around to the whole SS being stainless thing, so not sure what's going on there.
#79
#80
#81
Crap, look at the rust on the ground wire connection. That alone could be throwing the gauge reading out of whack. Probably want to go after that with some emery cloth or wire brush before putting things back together. You want shiny metal touching shiny metal when it comes to electrical connections.
2manytickets
1999 to 2016 Super Duty
13
04-23-2018 04:43 AM
biggyfan1
48
10-31-2013 07:26 PM
