1990 Ford 7.3 IDM???
Old Feb 26, 2024 | 02:36 PM
spraytruck's Avatar
spraytruck
1st Gear
Hello. Does a 1990 7.3 have an IDM? Mine had a rough idle problem then it went to running for a minute or so and shuts off. Could it be an IDM?
Blessings
Old Feb 26, 2024 | 04:44 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
No, it does not have an IDM or any other electronics.
Old Feb 26, 2024 | 05:40 PM
Prototypemech's Avatar
Prototypemech
Your problem is caused by an airleak in your fuel system. By your description, I can tell you the leak is between the fuel tank and the Lift pump thats bolted the the passenger side of your engine block. Check the rubber hose that connects the steel fuel line to the lift pump. Its a common failure point. Also check the rest of the steel fuel line for wetness, especially around clamps where corrosion can create pin holes in the steel fuel line.
67_4_ME
7.3L / 6.8L V8 Gasoline Engines
13
Feb 13, 2024 04:40 PM
Everlanders
Aug 13, 2018 02:30 PM
