E4OD overdrive shifting conditions
Old Feb 23, 2024 | 06:12 PM
Angel020920's Avatar
Angel020920
4wd Low
Hi to everyone, I got a problem with my transmission, not very bad, but still got me thinking about it
Is it normal the overdrive works only on 50-60 mph and just downshift to 3rd after 60 mph, but in uphills, when I put more throttle, the trans just upshift to overdrive and it climb in overdrive, slowing the truck, even flooring it doesn't downshift, only downshift when I turn off the overdrive, I checked wiring harness, the tps, but all those are good, no short circuits by the way, and the gears shifts good to, from 0 to 35 with almost no throttle goes from 1 to 3 without problem, even on city uphills while the trans is on 3rd, when I press the gas downshifts with no issues, only at highway speeds have the overdrive problem, also, the harness connector on the trans got the coast clutch solenoid pin broken (the original trans was replaced by another one from the junkyard), I know the trans is old, but is it normal to happen?? If the trans isn't reliable enough I want to try a manual bc I want the truck for heavy work, the truck is a ford F-350 1990 with the 7.5L or 460 engine
Thanks in advance
Old Feb 23, 2024 | 07:38 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Are there any codes stored? Here is how to check: www.troublecodes.net/ford
Old Feb 24, 2024 | 10:18 AM
Angel020920
4wd Low
Yes, but only the 93 code from the coast clutch solenoid pin that is broken, but that's it
Big_Z88
Apr 5, 2016 08:57 AM
chevyman98
Sep 30, 2012 04:43 PM
Sams_animal
Sep 20, 2010 06:09 PM
