Power Steering Pump
Old Feb 23, 2024 | 09:06 AM
eldomike51's Avatar
eldomike51
Power Steering Pump
The pump on my 1996 F150 4.9 constantly makes noise...tried different flds, no help....what replacement do you guys/gals recommend?
Old Feb 23, 2024 | 03:56 PM
'89F2urd's Avatar
'89F2urd
How bad is the noise?
Did you try lucas power steering stop leak? Ignore the name of "stop leak" for the purpose of this conversation.
The lucas is worth trying, because none of the pumps you'll get are as good as the one you have. If the lucas doesn't quiet it down enough to suit your liking, then just about any pump will be ok for the next few years
Old Feb 23, 2024 | 03:59 PM
My4Fordtrucks's Avatar
My4Fordtrucks
It’s a Ford CII pump. Most of them make noise. Type F is the recommended fluid in the owner’s manual. You could change to a Saginaw pump.
Old Feb 23, 2024 | 06:00 PM
Soup bean's Avatar
Soup bean
My truck was a project for several years, so I drove it in the driveway during that time.
The power steering pump was always noisy and the power steering pressure switch leaked.
After I replaced the pressure switch, I syringed out a pint or two of power steering fluid and topped it off with Wolf's Head Super Universal Synthetic ATF, because I already had it on hand for my M5ODR2 transmission.
It quieted way down. Hardly noticeable now.
Who knows, maybe the Ford recommended ATF would have accomplished the same thing but it's working for me, so I'm going with it.
eldomike51's Avatar
eldomike51
Yeah the Lucas was my first try....
Old Feb 23, 2024 | 08:08 PM
'89F2urd's Avatar
'89F2urd
the lucas leak stop? no noise reduction?
start learning about the saginaw pump, as stated above.
Old Feb 23, 2024 | 08:31 PM
AuroraGirl's Avatar
AuroraGirl
if you want to keep your C2 pump, try some seafoam trans tune and flush your fluid reservoir after a week witth something to suction it out, then fill with more fluid/seafoam then do that a couple of weeks. Then at that time, if your hoses are old, replace them(rubber breaks down internally) and install a power steering cooler and a magnetic filter on the return line. Then once fluid starts staying clean, do a full flush, and fill with the factory amount in manual + enough for the cooler setup and fill with quality type F fluid ONLY
Your unlikely to be fully satisified with this as it will be quieter but not quiet (probably.)
What engine do you have? the 5.0, 5.8, 7.5, and powerstroke disesels are easy to make saginaw pump styles.
The 4.9 can only "properly" be done by using E150-E350 van brackets which match your setup (year range and ac comp or not)
So there is only so many of those brackets out there and unless you find some in a yard its pricy on ebay. There is another known way to do it on a 4.9 but it involves removing an uncomfortable amount of support off the bracket for my liking.
Old Feb 25, 2024 | 01:19 PM
TobyB's Avatar
TobyB
I swapped my 4.9 to Saginaw when the soup can exploded, and while it's a bit quieter, it's still no silent runner...
...of course, I just used the junkyard pump that came with the bracket, so your mileage may vary!
t
Old Feb 25, 2024 | 06:02 PM
Prototypemech's Avatar
Prototypemech
https://leepowersteering.com/product...mp-replacement
I always thought this was the cats-meow. Ford housing with Saginaw internals. I haven't bought on yet, but it's on my wish list.
Old Feb 25, 2024 | 06:07 PM
AuroraGirl's Avatar
AuroraGirl
yeah if mine didnt work, sure, but hard to drop that when my c2 still does its job (somehow)
Old Feb 26, 2024 | 04:23 AM
My4Fordtrucks
Not for that kind of money. I converted the ‘87 Bronco and now the ‘89 F-150 to Saginaw pumps. I take the pump with pulley and pressure hose still mounted on the bracket to the junkyard cashier and pay less than $100 including tax.
Hundreds of thousands of miles on several different trucks with the Ford pump. The B2 has a Lares reman which has been great.
Old Feb 27, 2024 | 02:35 AM
AuroraGirl's Avatar
AuroraGirl
Lol I think if I were to tally my miles driving I probably only break 100,000 k, but I’m only 25 lol
Old Feb 27, 2024 | 05:41 AM
manicmechanic007's Avatar
manicmechanic007
Ford was too proud to put GM Saginaw pumps on many vehicles
A few stinkin Lincolns and a few vans is all
A shame
Old Feb 27, 2024 | 10:36 AM
'89F2urd's Avatar
'89F2urd
A shame
Too proud to keep pushrod engines too (until the 7.3 of course), which is a shame....the ls platform is way more like a next gen windsor than it was a sbc
thechief66
44
Aug 15, 2025 03:49 PM
Jamon Norton
Jan 1, 2024 09:57 AM
huntinzombie
Mar 28, 2010 03:33 PM
