Good news is everything on the 7.3 was photographed as it was stripped down.
Bad news is my phone bricked and took it ALL with it. Engine is going fine ( we have had the WORSE 3 years ever), BUT the extras are kinda hard to be sure on, like the water fittings on the heads...I have 2 but only see the one...yeah, i can figure it out eventually. Any help is appreciated. I miss my girl! working on some Ex pics...none on this puter so...here is Cujo and Lexi, Rotticorso and Great Pyrenees.
Does anyone have a link or build pics of a cleaned up 7.3 with a better look at that stuff?
I took some pics off Ebay stuff but some stuff is already stripped off.
Sucks...did all the work I needed to and tech bites me in the ***.
I use an App called "Telegram" to transfer pictures to the Web right away.
Telegram is available for Android, iOS, Windows, Mac, Linux, etc....
It syncs to any device you want, you use a common phone number for it to Sync from a PC to a phone.
"Saved Messages" belong to the Owner of the App, which is me in this pix....
the Other names you see are folks who have Telegram installed on their phones or PCs.
like the water fittings on the heads...I have 2 but only see the one... Any help is appreciated.
The second water fitting that is external to the heads (only applies to Excursions) is on the driver's side rear of the head, diagonally opposing the passenger front of the head.
Think of it this way: If you were to swap heads from passenger side to driver's side, where would the water fitting in the front of the passenger head end up?
