need to bleed power steering pump
Old Dec 24, 2009 | 11:02 PM
60RatRod's Avatar
60RatRod
I need to bleed the power steering pump but I don't remeber which is the feed and return at the P/S pump cooler. Any help would be appreciated.
Thanks and Merry Xmas
Old Dec 24, 2009 | 11:08 PM
zx250's Avatar
zx250
Of the next Riffraff East
Driving it will purge the air just about as fast as you can do it any other way. How did you get air in the system?
Old Dec 24, 2009 | 11:19 PM
BigAlsPSD's Avatar
BigAlsPSD
This might help
Power Steering Fluid Flushing Procedure For F250 Super Duty Truck
Old Dec 24, 2009 | 11:34 PM
mueckster's Avatar
mueckster
That's the procedure Rick (miller_feed) and I used when we did ours. We put Mobil 1 Synth ATF in there, too.
Old Dec 24, 2009 | 11:37 PM
zx250's Avatar
zx250
Yeah, that's what I did when I flushed mine, but he's wanting to know how to get air out. I guess that would also get the air out, but if don't want to change it out, wouldn't driving it purge the air in a short while?
Old Dec 24, 2009 | 11:59 PM
BigAlsPSD's Avatar
BigAlsPSD
yes it would eventually purge it self it is not a closed system
Old Dec 25, 2009 | 10:00 AM
60RatRod's Avatar
60RatRod
So I had to replace it recently (under AZ lifetime warranty) and never really got all the air out of the system.
Old Dec 25, 2009 | 02:12 PM
zx250's Avatar
zx250
Drive it, keep check on the level and it will be out shortly. Of couse you know that you need to use ATF and not powersteering fluid.
Old Dec 25, 2009 | 03:06 PM
lhud's Avatar
lhud
I just replaced mine while repairing the oil cooler and disconnected the return at the pump and put the end into a small catch pan.
I could see the air bubbles coming out as I moved the steering wheel to both sides and worked the brakes.
My system seems to be working fine right now.
Old Dec 25, 2009 | 07:03 PM
tbone heller's Avatar
tbone heller
Use the factory tool for bleeding p/s systems.Power Steering Evacuation Cap - 211-265 . I have made one of these out of a rubber ball with a 1/4" steel brake line through the center of it. Apply a vacuum pump to the 1/4" tube, place the rubber ball over the p/s reservoir, start the truck, apply vacuum, turn steering wheel lock to lock. All of the air will be sucked to the top of the reservoir. After a few minutes, all air will be gone. The p/s pump will make a lot of noise while under vacuum but, it will quiet down when you release the vacuum. The homemade bleeder can be made for less than $2.00 & will last for years.
Old Jan 1, 2010 | 11:55 PM
Griff350's Avatar
Griff350
tbone, what kind of rubber ball did you use?
Old Jan 2, 2010 | 12:09 PM
60RatRod's Avatar
60RatRod
Sounds cool, do you have any pics? I have an extra cap I picked up from the junkyard I wonder if it woul create a vacuum tight seal, if so I guess I could drill and tap a 1/4' nipple to that. I still have'nt found anyone to help me pump my brakes and turn my wheel so I can bleed using the factory reccommended prcedure.
Old Jan 4, 2010 | 07:30 AM
tbone heller
I don't know. It is about the size of a tennis ball & it is solid. It is like a giant "superball". I think it came from the toy dept. at K-mart.
Old Feb 25, 2024 | 11:44 AM
Blarp's Avatar
Blarp
2nd Gear
Old Feb 25, 2024 | 12:34 PM
Tpayne621's Avatar
Tpayne621
I hope hes still not trying to bleed the power steering 14 years later. Could be wrong though. I've seen crazier stuff. lol
