Door locks
Old Feb 22, 2024 | 06:18 PM
smsluck13's Avatar
smsluck13
1st Gear
Door locks
Might be a stupid question...
Just got a 97 f350 7.3l, found out that both power door lock switches work, but the manual key locks don't. Both front door cylinder locks turn only one way. The driver's side will only lock with the key. The passenger side will only unlock with the key. Am I missing something obvious or do I need new cylinder locks?
Old Feb 22, 2024 | 07:46 PM
1994F2507.3L's Avatar
1994F2507.3L
There’s a decent chance the mechanisms are frozen / binding inside the door. When I had my panels off I hosed everything down with silicone lube (same stuff used on the window tracks that’s rubber / plastic safe) and they freed up a whole bunch.
Old Feb 22, 2024 | 08:16 PM
96SD's Avatar
96SD
Silicon spray I put the S%^$ on everything!
Old Feb 23, 2024 | 08:19 AM
Hit Man X's Avatar
Hit Man X
But yep, that works well. WD40 has nice rust penetration stuff. Not as good as say Kroil, but works.
Old Feb 24, 2024 | 03:36 PM
defdes's Avatar
defdes
I have the same issue, can they be freed up solely by spraying in thru the key slot repeatedly and wiggling the key, or do the inner panels need to come off for the full treatment?
Old Feb 25, 2024 | 07:43 AM
97-psd's Avatar
97-psd
I have had good luck going through the key hole. To lube everything you will need to remove the panel
bwguardian
Nov 12, 2022 02:38 PM
Curt Bates
Jul 10, 2013 07:06 AM
deerslayer joe
Sep 21, 2009 07:56 PM
uralista
Electrical Systems/Wiring
Sep 29, 2003 05:05 PM
MDK
1997 - 2003 F150
Sep 5, 2003 08:29 PM
