Replacing Front Rotors Question
Old Feb 21, 2024 | 08:07 AM
soaust's Avatar
soaust
I just did ball joints and tie rods on my 1995 F150. Alignment shop told me I needed new front rotors, pads, and passenger side caliper. Just wondered if I have to take wheel bearings out to get rotors off, should just go ahead and put new wheel bearings in too? I did them 2-3 years ago.
Old Feb 21, 2024 | 08:20 AM
tjc transport's Avatar
tjc transport
i ain't rite
two wheel drive yes. i believe the 4 wheel drive rotors are slide on.
Old Feb 21, 2024 | 10:29 AM
Hit Man X's Avatar
Hit Man X
Is there a current issue with them?
Old Feb 21, 2024 | 12:12 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Not unless you find they are bad. Otherwise clean, inspect, repack with grease then reinstall.
Incorrect. The lug studs need to be pressed out to separate the hub from the rotor.
cphill58
Aug 26, 2012 04:18 PM
mach1cj
2004 - 2008 F150
Aug 30, 2011 07:06 AM
johnfrommissouri
Sep 7, 2009 08:52 PM
Vankaye
Jul 23, 2007 10:03 AM
Downriver Thunder
Feb 16, 2006 07:39 AM
