Electronic Locking Axle, Necessary?
Old Feb 20, 2024 | 07:51 PM
  #46
scraprat's Avatar
scraprat
Top Answer: 5
Originally Posted by Desert Don
Yeah, I have been in a few situations where lockers would have helped. Then I built a rig with selectable lockers, front and back, and just ended up in deeper situations………still stuck!! Just deeper!
That is the great thing about 4x4 when you're stuck noone is around and gives time to reflect on the circumstance.
Old Feb 21, 2024 | 08:41 AM
  #47
Bigredtoy's Avatar
Bigredtoy
It's like insurance. If you have it and don't need it you lose a little. If you don't have it and need it you lose a lot. I mean you're spending a min $60,000 (probably a lot more) for the truck, how much more is a locking rear??
Old Feb 21, 2024 | 11:43 AM
  #48
twobelugas's Avatar
twobelugas
People will spend thousands upon thousands for convenience and creature comforts but skip some of the most useful features on a truck. Kinda like how many 70k+ SDs I see have no rear wheel well liners.
Old Feb 21, 2024 | 12:42 PM
  #49
Sport45's Avatar
Sport45
Huh? I don’t have rear wheel liners and don’t have a clue what would make them so necessary. I guess each of us has different needs and having options is a good thing.
Old Feb 21, 2024 | 12:47 PM
  #50
ShotgunZ71's Avatar
ShotgunZ71
Potentially a whopping $430 if not included in your build. Agree, quite an insignificant amount, considering.
Old Feb 21, 2024 | 12:49 PM
  #51
twobelugas's Avatar
twobelugas
you said it, I didn't.
Old Feb 21, 2024 | 12:52 PM
  #52
HRTKD's Avatar
HRTKD
The liners come in handy for when the tire tread picks up rocks and flings it into the wheel well. Less noise, no dents. If you get into mud, the liners are easier to clean.
Old Feb 21, 2024 | 12:59 PM
  #53
twobelugas's Avatar
twobelugas
they also really help with snow and associated debris that build over time. I see so many trucks with everything under the frame covered with road spray in the winter when I head into the hills. Can you spray them out with a hose? Sure, with some effort, but with so many electrical wires and connectors under the bed these days, you have to straddle a fine line between wash away caked on dirt/mud mixed with sand or salt, but not so strong that you get water into places you don't want water.
Old Feb 21, 2024 | 01:23 PM
  #54
FishRanger's Avatar
FishRanger
Wheel well liners, front and rear $325. They are on my order. I just don't like the looks of my trucks without them.
It's ridiculous they aren't standard equipment.
Old Feb 21, 2024 | 01:30 PM
  #55
6.8L_V8_DRW's Avatar
6.8L_V8_DRW
I think they make a truck look feminine. But to me any truck over an WT/XL looks like a Barbie toy.
It is ridiculous all the junk they put on a truck.
  #56
OverheadCram's Avatar
OverheadCram
My vote is skip it. My primary business for 20+ years was land clearing. Spent plenty of time in loose soil, loose debris, mud, snow, and ice and there were maybe a handful of times having that extra wheel powered would have got me any further. Even those few times if I did get further it would have just ended with three spinning wheels instead of two. The right set of tires will get you the best results.
Old Feb 21, 2024 | 01:32 PM
  #57
twobelugas's Avatar
twobelugas
The list of items that I made sure to include on my order even as a more budget oriented work truck:
-locking rear diff
-wheel well liners
-upfitter switches
-trailer brake controller
I think the liners are standard on limited and platinum. For 90k-100k they better be included, lol.
Old Feb 21, 2024 | 01:42 PM
  #58
OverheadCram
Up here in the Northern parts the wheel well liners on the steel bodied trucks are a guarantee your bed sides will rot away many years prior to ones without. Its nice being able to actually clean the sand out from under the bed and it not get stuck in the top of the liners holding moisture. Not too worried about the aluminum bodies now but still have no desire to fit a liner.
  #59
Bigredtoy's Avatar
Bigredtoy
I agree! I didn't know they weren't!!
Old Feb 21, 2024 | 02:16 PM
  #60
twobelugas's Avatar
twobelugas
The front fender wheel wells all have a liner/splash shield of some sort and that would mean the trucks without rear liners would rot out from the front anyway. Considering most vehicles on the road have wheel well liners, face it, Ford left the rear bare to save money and be able to nickle and dime lower trim truck customers, similar to how starting in 23 you cannot get a 7.3 gas motor without paying for 4wd and also buy a mandatory 5k driver's nanny program on top of the motor upcharge, or directly starting at an XLT. In 2022 you could get a 2wd XL 7.3 in the low 40k range if you skipped other options. Today you cannot get a 7.3 without spending about 58-60k depending on cab size even if you don't need 4wd, driver's nannies, and other assortment of mandatory packages.
