Electronic Locking Axle, Necessary?
Old Feb 20, 2024 | 10:31 AM
Just Chilling's Avatar
Just Chilling
Do these automatically unlock after a certain speed? I always crawled underneath and unplugged them because I was afraid the steering wheel holder would forget to turn it off and destroy the rear end.
Old Feb 20, 2024 | 10:33 AM
arto_wa's Avatar
arto_wa
Originally Posted by Desert Don
Please explain to me how that MOST of the time in poor traction conditions with an open diff I have BOTH rear wheels spining then. Just asking.
I am not saying lockers or a LS rear won’t help because in a lot of situations they do.
Lift one rear wheel off the ground and put it in drive to see what happens?
Old Feb 20, 2024 | 10:51 AM
Desert Don's Avatar
Desert Don
Then you do NOT have one wheel drive; you are stationary (NO wheel drive)!
Old Feb 20, 2024 | 11:01 AM
jade97's Avatar
jade97
No it is not automatic. Once in 4wd, if you want the electronic locker to engage, you need to pull the 4wd **** outward.
Old Feb 20, 2024 | 11:15 AM
Desert Don's Avatar
Desert Don
they DO automatically disengage above a certain speed. AFAIK.
Old Feb 20, 2024 | 11:20 AM
Sport45's Avatar
Sport45
Yes, the axle unlocks automatically at 25mph or so and then reengages when the speed drops back down if you accidentally leave it locked in.
Old Feb 20, 2024 | 11:30 AM
Sport45's Avatar
Sport45
2-Wheel drive without limited slip or "locking" rear axle is actually 1-Wheel drive!
Not really. Both rear wheels get the same amount of torque. The tire with the least traction will break loose first.
On a slick hillside having one wheel on each axle not spinning keeps you going the direction you want. If both tires are spinning on an axle that axle is going to want to go sideways down the hill.
That said, I have the electronic locker but haven’t used it. The weight of the diesel over the front axle along with the traction control system has gotten me everywhere I needed to go. Others have different needs. I think the OP would be well served with 4x4 (not Fx4) and a non locking rear.
Old Feb 20, 2024 | 11:58 AM
WXboy's Avatar
WXboy
Ford blew it. A limited slip diff like Ram uses is FAR more useful to the average guy. Even better is the automatic mechanical locker that GM uses. Both are seamless, increase traction, are great to use ON the road as well as off the road, and don't require any intervention from the driver. I don't know what Ford was thinking when they spec'd the axles in the Super Duty trucks.
Old Feb 20, 2024 | 12:22 PM
DPelletier's Avatar
DPelletier
My F350 has limited slip which requires no thought and is better for what I do with my truck.......the electronic locker is better for actual offroad use and I like that you have to physically engage it because I suspect there are times where an automatic system like GM uses could cause stability issues.
I still say buy the locker; it's cheap and you might really need it one day but if not, it may be an easier truck to sell when the time comes. Funny thing, in Canada, I couldn't option an F350SRW without the locker.....maybe it's like the cold weather package (block heater and rapid heat) on the diesels which are standard on trucks to be sold in Canada.
Cheers,
Dave
Old Feb 20, 2024 | 01:20 PM
WXboy's Avatar
WXboy
Cheers,
Dave
I didn't think F-350 had a limited slip option? Open diff or e-locker only, right?
Old Feb 20, 2024 | 01:24 PM
user 474747383's Avatar
user 474747383
All my 350's have 4:10 limited Slip DRW's
Old Feb 20, 2024 | 01:25 PM
MBuckholz's Avatar
MBuckholz
A four-wheel drive super duty with open diffs is two-wheel drive in slick conditions. A two-wheel drive with a locking diff is two wheel drive in slick conditions. In your situation I would buy a cheaper more efficient better riding less hassle two-wheel drive and opt for the optional locking diff. And the locking diff disengages at 25 miles an hour
Old Feb 20, 2024 | 01:26 PM
  #28
6.8L_V8_DRW's Avatar
6.8L_V8_DRW
DRW has limited slip. No e lock on duals.
Old Feb 20, 2024 | 01:38 PM
  #29
twobelugas's Avatar
twobelugas
unless OP is willing to rough it with an XL, 23+ XLT and up are all 4WD now. CC XLT start a 57500, might as well get the locking diff, saving 430 dollars on a 57.5k truck seems like buying a Corvette but insist on all season tires.
Old Feb 20, 2024 | 02:19 PM
  #30
redford's Avatar
redford
FTE Leadership Emeritus
Yes, 20MPH IIRC.
