95 7.3 e4od hard shift rough idle
Old Feb 19, 2024 | 10:59 PM
swirlytoaster's Avatar
swirlytoaster
4wd Low
Hey guys I just bought a 95 7.3 4x4 with the e4od and I’ve ran into a little problem, when I start the truck in the morning it starts good runs good, but it has a very slight rough idle, when I start to drive it hard shifts if I’m easing into it or wot, the only time it doesn’t is when I’m 50% throttle, slowly as the truck warms up the rough idle gets worse and feels like it is bouncing me out of my seat, the hard shifts also get worse like it’s hesitating to shift and then bangs into the next gear, also if I’m driving down the highway at 100kmh and let off the throttle the tc will unlock(not sure if it’s supposed to do it), I checked the map wiring, all brake lights unhooked trailer brake controller Speedo and tach both work good, I haven’t had time to really dig into it and my mucar won’t scan it any place to start would be good thanks in advance
Old Feb 20, 2024 | 08:02 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Reading the codes is always the place to start. WIthout the codes all anyone can do is guess.
Old Feb 20, 2024 | 10:50 AM
swirlytoaster
4wd Low
hey thanks for the reply, I might have someone who can read it tomorrow, no cel and I don’t remember if I mentioned but my lift pump is leaking pretty bad, I also tried unplugging the icp and the baro and no changes whatsoever tia
Old Feb 20, 2024 | 11:57 AM
knottyrope's Avatar
knottyrope
https://www.ford-trucks.com/forums/1...-to-clean.html
What is your fuel pressure?
scanner info
https://www.ford-trucks.com/forums/1...2-scanner.html
Old Feb 20, 2024 | 12:11 PM
swirlytoaster
4wd Low
Originally Posted by knottyrope
just rigged up a Schrader to a gauge I’m gonna check tonight after work
Old Feb 20, 2024 | 09:46 PM
swirlytoaster
4wd Low
I checked at idle and it’s very low 25 max
Old Feb 21, 2024 | 08:12 AM
knottyrope's Avatar
knottyrope
injectors need 45 PSi
Change the pump and clean the bowl out too or it can kill the pump quickly
Daniel Botelho
Jan 17, 2024 10:00 AM
WolfMann
Nov 12, 2023 08:22 PM
Patdietz
Oct 19, 2023 09:10 AM
nick83f150
Sep 2, 2018 08:24 PM
speed1972
1978 - 1996 Big Bronco
Jan 31, 2003 12:59 AM
