Modular V10 (6.8l)
Power Steering Pump Replacement
Old Feb 19, 2024 | 03:56 PM
Bello1's Avatar
Bello1
2nd Gear
Ok so im not sure if its ok to make new threads on possibly a topic that already has pr3eviously been used. IDK, anyway I have a power steering leak at the pump. I have removed it and am ready to put all things back together however because I think there's been tampering with my truck I want to make sure that all the lines from the power steering reservoir/pump/cooler-(radiator area)/ and gear box are correct and I don't have a swap somewhere. any in depth line diagram / picture of the entire system would be great. like I said in my new come post I'm a complete noob to this so I apologize. ITS not allowing me to post the picks but I will from another outlet
Rear driver side suspension
Passenger side rear. What’s is the line coming out from the tire area
Passenger side front leaf spring area
Again passenger side at leaf spring connection p
Power steering reservoir
Gear box mounted to frome
Gear box 2
Electrical under driver from wheel well I believe
Driver
Driver side connection to suspension at frame? Shouldn’t there be more then just this
Axel to tire connection. something about it seems wrong
Old Feb 21, 2024 | 10:34 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
[QUOTE=Bello1;21140116]
Passenger side rear. What’s is the line coming out from the tire area Brake line
Driver side connection to suspension at frame? Shouldn’t there be more then just this Not my favorite bracket, but it looks okay for light duty. This is just for the shock absorber, so not a lot of strength is needed.
[/QUTE]
ford4x477
36
Apr 10, 2024 08:21 AM
lshort
Dec 29, 2022 09:00 AM
650
Sep 4, 2022 12:35 AM
GTOnly70
Jan 2, 2022 07:53 PM
Christopher Paul
Aug 7, 2015 09:19 PM
