Assume stuck thermostat?
Is this the correct symptoms of a stuck thermostat? My truck has always been slow to warm up but I drive like grandpas's grandpa.. How long does it take yours to warm up?
I usually don't drive it much in cold temps (and rarely unloaded) so it gets up to "operating temps" but I am driving today in closer to freezing and unloaded ... . After driving for 20 min at about 45mph it is still only at 145 degrees... just doesn't seem right..
not looking forward to fighting that if so. It could be original bolts by the looks of it.
I would say you have an issue.
My truck is at around 200 degrees eot in about 10 mins of light driving in winter. Slightly depends on temps out side and what i am doing. That said, i drive for fuel economy so i too do not have a heavy foot ( nut well adjusted).
I run the 195 * tstat (the step up that riff raff offers) and a bra in the winter, no ebpv. Without the bra, it still gets warm quickly.
Tstat would be where i start. Get an oem one. I like the warmer one for winter alot, mind you, we have 6 months of winter.
That is definitely not normal. I had a bad fan clutch that was stuck on just recently but it would still hold 180-190 with a properly working T-stat running down the highway.
I would say try a new Motorcraft t-stat. I've had bad luck with other ones. Consider a billet aluminum housing for it also. A rare example of the OEM part being crap.
The following users liked this post:
I put a duralast t-stat in mine 5 years ago. Never connected the dots that I never had heat again in winter until this year. Figured it must be stuck open and replaced it with motorcraft. I found the duralast one was a "fail safe" unit that sticks open the first time it opens by design. Garbage!
This is what last weekend had in store for me.
3 for 3 snapped off
Prepped for replacement
Job is done.
Not exactly what I had planned for t-stat replacement during coolant flush and conversion over to ELC.
