Aerostar Ford Aerostar
Wont warm up
Old Jan 15, 2005 | 09:59 PM
Machman's Avatar
Machman
Wont warm up
Heres a good one. 91 3.0 runs good but takes a while to warm up. I replaced the thermostat and flushed the system with new antifreeze and it still seems to take too long to get warm. It will go to the first line on the gauge and nothing more. I seem to have decent heat from the vents but not as it should be. How do I check the fan clutch? It spins ok with a little drag when cold. Any help would be greatly appreciated.
Old Jan 15, 2005 | 10:37 PM
krankshaft's Avatar
krankshaft
If the fan clutch is failing try this with a cold engine it should turn with minimum resistance but it shouldn't freewheel (continue turning after you push it).
From what you said it seems to be fine.
Are you sure you installed the thermostat in the right direction? Also check to make sure its not sticking or opening too early.
Old Jan 15, 2005 | 10:40 PM
copper_90680's Avatar
copper_90680
It's the temperature sender switch. I have always thought my engine runs too cold until I replaced that switch. You can take it out and dunk it in boiling water while measuring the resistance. It should be about 27-28 ohms in boiling water. I suspect yours would read much higher than that, perhaps 100 ohms or so like mine did.
Old Jan 16, 2005 | 07:52 AM
b2trausch's Avatar
b2trausch
What temp thermostat do you have installed? In the colder climates, you'll find that many people install a thermostat that opens at a higher temp. The effect is that the engine warms up to a higher temp before the thermostat opens, and this translates to warmer air coming from the heater. I have a 192 degree thermostat installed in my 93 4.0. The coolant temp displayed when fully warmed up is right in the middle of the range.
Good luck.
Old Jan 16, 2005 | 08:19 AM
Machman's Avatar
Machman
195* thermostat brand new from NAPA. I think I will test the sender.
Old Jan 16, 2005 | 01:31 PM
Beast12's Avatar
Beast12
I had the same problem in my truck. It would only go up to the bottom of normal. I changed out the sender and no change. So, I went and bought a Motorcraft thermostat, always sits in the middle now. I have heard NAPA thermostats are not too good but I do not have first hand experience with them. Good luck.
-Matt
Old Jan 18, 2005 | 09:32 AM
rickm5's Avatar
rickm5
since i seem to be in the same boat i thought i'd ask...where is the temperature sending unit? i replaced my thermostat last year. only warm again. what makes the thermostat go bad? too much back pressure from a clogging heater core? just wondering ....i don't really want to change a thermostat in the driveway in this weather unless i have to.....bbbrrrr..4 degrees in ohio....rick
Old Jan 18, 2005 | 08:24 PM
Machman's Avatar
Machman
I think it is a junk thermostat from NAPA. I checked the temp with a handheld infrared laser temp deal and it only showed 152*(upper hose) after idling for about 20 minutes. Everything points to a bum thermostat. I am going to try a motorcraft this weekend and see what happens. I will post results.
Old Jan 19, 2005 | 10:22 AM
aerocolorado's Avatar
aerocolorado
While you're under the hood, and the engine is at normal operating temperature, check the two hoses going to and from the heater core. (At the firewall on the passenger side.) Both hoses should be same temperature (hot, ideally) to the touch. If one is noticeably cooler, your core may be plugged and needs backflushed to restore operation.
Old Jan 19, 2005 | 11:27 AM
krankshaft's Avatar
krankshaft
Just out of curisoity are the heater core hoses the two hoses that run over the alt on the passenger side on my 96 3.0?
I think they are because there are two next to each other one to enter the core and one to leave but I'm not sure.
If they are it was such a good idea for Ford to run these hot hoses and let them lay directly on top of the alt its got enough heat conducting from the engine to worry about .
Well just like their put the cat next to the tranny bellhousing so it bakes the seal idea.
I gotta say I love the van but not the stupid design.
Old Jan 19, 2005 | 07:33 PM
Machman's Avatar
Machman
Well,I put in a motorcraft thermostat and it seems to be a little bit better but not enough to say that was it. It still sits at the line below the n in normal. It initially went to the n and then when the stat opened,it went down a line. Both heater hoses are the same temp. I still need to check the sender. If all else fails, I am going to block off a section of radiator and see where that gets me.
Old Jan 19, 2005 | 08:22 PM
eehoepp's Avatar
eehoepp
Machman: Is this warm-up problem new or did you experience the same thing last winter?
I have a 95 3.0L & mine behaves similar, as it has every winter I have had it. In my case I flushed the cooling system (two or three time), replaced the 'stat (twice), rad cap, water pump, the hose to the overflow tank, various other hoses...
It still behaves the same: gets warm, but not hot enough for the computer to get into "closed loop", so the gas mileage bites. I have come to the conclusion that this van just does not produce a lot of heat. The best investment I made last year was a "winter front" - one of those quilted vinyl grill covers. By restricting the air flow through the rad, the engine gets fully up to temperature (and stays steady), the heater blows hot, and the gas mileage is comparable to summer.
You can get the same result with a piece of cardboard, but that tends to get soggy if you get a lot of wet snow.
Good luck with your troubleshooting.
Cheers,
Eric
Old Jan 22, 2005 | 09:06 AM
Machman's Avatar
Machman
The motorcraft thermostat did seem to make a difference. I went on a long drive last night and the temp was right between the n and the o and when it opened, the needle would drop a line or two and then gradually come back. The wife tells me it always ran cool in the winter, so maybe I am just over analyzing this temp thing. I think I am going to block off part of the radiator for the winter and let it go. There definately was a change between the motorcraft and the napa parts though.
Old Jan 22, 2005 | 09:31 AM
Beast12's Avatar
Beast12
When I had my A* it seemed like it would not heat up as much as other vehicles I had before. Maybe it is just a characteristic of some of them?
-Matt
Old Jan 30, 2005 | 05:25 AM
428_cobra_man's Avatar
428_cobra_man
Smile
Well it may suck that they dont heat up fast enough in the cold of winter, but I am happier knowing that they run cooler, moreso if i owned a 4.0L because they overheat and the heads seem to warp, i have gotten away with murder on my 3.0, my thermostat failed and by the time i noticed the temperature the needle on the guage was right as hot as it goes, and it was running strange.. lol i wrapped a thick towel around the rad cap and took it off and got the heck outta the way. It puked out every last drop of coolant and i swear if the hood wasnt blocking it it woulda shot 20 feet in the air. If only they made the 4.0's cast Iron block with Cast Iron heads like the 3.0 instead of Aluminum then they would really be a good motor. I really cant say anything good about 3.8's oh well at least they dont come in aerostars. :P
