Starter blues
Old Feb 18, 2024 | 09:22 AM
Waylon14's Avatar
Waylon14
3rd Gear
Starter blues
Not sure if I'm doing this right. But here it goes. 91 f150 4.9. I crank my truck and one out of five time the starter engages. It always spins but intermittently engages. Brand new battery, fender mounted relay, ground wire and clean all other connections.
Old Feb 18, 2024 | 09:47 AM
AuroraGirl's Avatar
AuroraGirl
If your connections ARE good, then the part of the starter that kicks out, the bendix, is not working right. I would advise upgrading to the PMGR starters from like 93/94 + 4.9 and being done with it. They are smaller, last longer, and are better at cranking over.
Old Feb 18, 2024 | 09:51 AM
Waylon14's Avatar
Waylon14
3rd Gear
First I tried a re-pop from napa then a brand new one from autozone. I just can't convince myself that it could be 2 bad ones in a row. Thanks for the response. I'll see if I can find another one.
Old Feb 18, 2024 | 11:14 AM
My4Fordtrucks's Avatar
My4Fordtrucks
I believe it. Three bad reman p/s pumps from Napa. First didn’t have any pressure. The next two were louder than my old leaking pump. They wouldn’t warranty the third one. Basically told me is was “normal” and to live with it.
Old Feb 18, 2024 | 11:38 AM
Prototypemech's Avatar
Prototypemech
Bad starter bendix. Replace the starter.
Old Feb 18, 2024 | 12:34 PM
Hit Man X's Avatar
Hit Man X
I had three bad remans that would drag on the flexplate on a BMW of mine. Finally broke down and bought a Bosch reman, no issues.
It was obvious that two were dropped in transit.
Old Feb 18, 2024 | 01:04 PM
aquanaut20's Avatar
aquanaut20
You may have low voltage to the starter, perform a voltage drop test on the main starter feed cable..
Old Feb 18, 2024 | 02:18 PM
JehD's Avatar
JehD
Then let me help you out with that…YOU CAN GET MULTIPLE BAD ONES IN A ROW…
All kidding aside unless you absolutely positively gotta with out an excuse have to have it today dont get inexpensive no name electrical parts from the box stores. Do yourself a favor and get a quality brand name from a place like Rock Auto. Motorcraft, Bosch, Delco. While the box stories may have a lifetime guarantee….you will spend a lifetime doing them.
Old Feb 18, 2024 | 08:33 PM
Waylon14's Avatar
Waylon14
3rd Gear
Thanks for the advice. Ordered a Bosch will be here Tuesday.
Old Feb 19, 2024 | 04:28 AM
manicmechanic007's Avatar
manicmechanic007
Bench test the starter you have now
Buddy of mine, his Jeep just clicked, he replaced the starter and it still just clicked
Got me over there to look it over
Found the engine seized by the failed A/C compressor hub bearing froze up
Noticed the belt was loading on his and the crank was turning about a quarter of an inch each time we tried it
So, if your starter bench test fails, get another one
Put a wrench on that crank bolt and spin the engine before you get too far into it
Old Feb 19, 2024 | 04:49 AM
charlie g's Avatar
charlie g
FTE Community Team
with above about bench testing, simple but tells the truth, another item i would look at when it's next out,
since it's a 4.9 pull the spark plugs, have someone using a socket and bar turn that motor over while you CLOSILY look at the starter ring gear, look for damaged teeth if it has any you will be pulling the trans to replace either the ring gear if it's a stick or the flex plate.if it's a auto trans.
dbail3
Electrical Systems/Wiring
Sep 18, 2014 07:07 PM
ericconn
Jun 3, 2013 10:33 AM
blackbull
Feb 22, 2009 12:38 AM
69mustang
Aug 2, 2004 03:42 PM
bocky65
Jan 2, 2003 10:38 PM
