Injector knock?
Old Feb 16, 2024 | 08:44 PM
GavinL's Avatar
GavinL
Injector knock?
Hey all, I've got a 2015 f-250 6.7 181k miles,
Little back story: randomly and intermittently will get a "Diesel Exhaust Filter overloaded, drive to clean" and sometimes followed with a random misfire. If it starts misfiring I shut the truck off, start it back up and It runs fine.
Just got a knocking noise, I believe to be my Cylinder 4 injector bad. Getting codes for Cyl. 4 Contribution balance and Cyl. 4 misfire. If I go in FORScan and disable the #4 injector it the sound mostly stops but almost still sounds like there's a small ticking noise.
Anyone know the cause of this? No blowby, so I don't believe its a rod. Doubt its a spun bearing or anything. Maybe a rocker arm issue? Praying its nothing bad cause I'm supposed to be on a road trip in less than 2 weeks with it
Old Feb 17, 2024 | 06:13 AM
senix's Avatar
senix
with this many miles and the code for #4 I would change out that injector. Be sure to update the injector into forscan.
Old Feb 17, 2024 | 11:56 AM
FishOnOne's Avatar
FishOnOne
Very lilkely a injector issue. Some have double dosed with Diesel Kleen fuel additive to resolve this issue. Wouldn't let it go on for too long.
Old Feb 17, 2024 | 08:19 PM
krc0864's Avatar
krc0864
I had an injector knock that would come and go. Never got a check engine light but was finally able to catch it knocking when I could get the IDS on it. Contribution test did not reveal an issue in my case. Started killing injectors till the knock went away. Replaced the injector and no issues since.
Powerstrokeforlife
General Diesel Discussion
Sep 26, 2019 09:28 PM
Blackened88
May 17, 2017 12:51 PM
can't dance
Feb 27, 2013 07:59 AM
Bigfwt04
21
Dec 17, 2008 10:52 AM
JockD
Oct 22, 2008 07:34 PM
