E4OD Question
Old Feb 19, 2024 | 03:48 PM
Divemaster5734's Avatar
Divemaster5734
Nothing on the dash either.
AuroraGirl's Avatar
AuroraGirl
Originally Posted by Divemaster5734
Just the standard D 2 1.
Maybe Ford didn't include the OD off because they were marketing an SUV with the Centurions, and weren't concerned about the loads?
When they stopped those and the Broncos they came out with the Expedition and Excursion models.
I heard they never made a yellow excursion because their consumer tests always took those for school busses.
i can almost guarantee you ford didnt ship that truck with a C6 column and an E4OD. either the E4OD was added without the necessary other stuff or the column was swapped (id be suspecting that way more since how easily the shift tubes on these break)
Old Feb 19, 2024 | 04:09 PM
Divemaster5734
All I know about the build is Centurion got the truck straight off the assembly line and did the modifications.
I can't imagine why they'd replace the column.
It does have a cruise control steering wheel.
Don't know if that was standard on the f350 base.
Some of their electrical mods were heinous.
But then, I'm a major wiring snob.
Old Feb 19, 2024 | 04:13 PM
AuroraGirl's Avatar
AuroraGirl
Im not a wiring snob and I have large issues with many of fords factory wiring choices. like not using Relays for headlamps, running blower motor power through like 10 feet and 5 connections (instead of using a relay) , the ground situation, the wiring insulation , some routing (not much)
proprietary connectors that they discontinue frequently, etc
Old Feb 20, 2024 | 07:20 AM
Jim_K's Avatar
Jim_K
So you have a "standard" column (my term), with an E4OD, and no OD button....
"Curiouser and curiouser!"
Old Feb 20, 2024 | 12:18 PM
Divemaster5734
Today's the day she's getting towed to either the final resting place, or her transformation to a lightly use 7.3idi with ZFZ542.
I don't trust the E4OD that's in it and might just do the full rebuild with shift kit and Gear Vendor planetary output.
The auto to stick doesn't look too bad as it's a mechanical clutch.
Ordered a South Bend clutch good for 400/800 with solid flywheel conversion.
I'm now questioning the actual depth of my insanity...
Mad.Scientist
Aug 16, 2009 07:00 PM
trailblazr81
Jun 20, 2007 07:48 PM
Mark 42
Dec 15, 2006 05:09 PM
vento
1978 - 1996 Big Bronco
Sep 1, 2006 08:46 AM
bigbluebronco43
Nov 21, 2004 07:58 PM
