6.7L maintenance needed?
Old Feb 12, 2024 | 10:19 PM
mbrowne's Avatar
mbrowne
I have 225000 miles on my 2017 F250 super duty. What maintenance should i do for this summer's towing. I have never needed to do anything to this truck and hope to keep it going. I was thinking about replacing the belt and idler pulleys and maybe the water pump. Is there any recommendations. The only thing I have replaced is both battery's and the intake hose. tires and front brakes.
Old Feb 12, 2024 | 10:32 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Coolant flush, trans fluid and filter change, F&R axle lube change, transfer case fluid change.
Old Feb 13, 2024 | 12:08 AM
mwheue's Avatar
mwheue
+"brake fluid and power steering fluid
Old Feb 13, 2024 | 05:25 AM
senix's Avatar
senix
all the above, in addition I would lift each front tire off the ground slightly and put a pry bar under each wheel and lift the tire.
Will need someone to do that for you while you look underneath and watch the suspension components.. You are looking for wear at the ball joints.
Old Feb 13, 2024 | 06:40 AM
WXboy's Avatar
WXboy
Yep at 225k that should have all been done twice already. If he hasn't he REALLY needs to do those.
Old Feb 13, 2024 | 07:20 AM
OX2's Avatar
OX2
OP does not appear to be asking about "routine" maintenance. More on pre-emptive maintenance, of possible
known failure points, that are "reasonably" easily replaced, at that high a mileage.
Brake fluid is still a good one, as most don't do it in routine maintenance (heck, some never do it)
Old Feb 13, 2024 | 08:52 AM
09FX-4's Avatar
09FX-4
I'm pretty sure he's on top of all of that stuff by now...
I'm considering changing out the CP4 at 200k, so that might be something you want to consider.
Old Feb 13, 2024 | 09:03 AM
redford's Avatar
redford
FTE Leadership Emeritus
All of the above, plus:
Even though you serviced teh front brakes, eyeball the brake pads for excess wear or abnormalities. Clean and lubricate the slide pins.
Remove, clean and lubricate the 4x4 lockout hubs. Verify correct operation.
Inspect shock absorbers and steering stabilizer for leaks, rust, or other abnormalities.
RV_Tech
Oct 28, 2022 08:19 AM
myblkex
Dec 8, 2012 01:29 PM
Powerdude
2009 - 2014 F150
15
Sep 13, 2010 08:56 AM
TDN
May 24, 2005 06:16 PM
OfficerLow
Oct 20, 2004 07:57 PM
