Track bar
Old Feb 12, 2024 | 03:48 PM
Jamon Norton's Avatar
Jamon Norton
Track bar
I just rebuilt the front end on my 1999 F250 super duty 4 x 4 I replaced the tie rod ends and ball joints took it for an alignment and it needs a track bar. Was just wondering what was a good one to go with I don’t mind spending the money to put a good part on it. The truck is not lifted. It is stock height running 33-12.5-20 tires
Old Feb 12, 2024 | 04:32 PM
97-psd's Avatar
97-psd
Is there a reason you can’t just put new bushings in it? Unless it is damaged I do not know why you would need a whole new one
Old Feb 12, 2024 | 05:59 PM
Jamon Norton
you don’t need a press to do the bushings?
Old Feb 12, 2024 | 06:57 PM
Jamon Norton
Also the truck is a 3/99 build date so I need the early 99 part ….. truck has early 99 front suspension parts from what I can tell, ik the brake rotors were but the engine is late 99
Old Feb 13, 2024 | 09:30 AM
Tpayne621's Avatar
Tpayne621
You can get a complete moog track bar for a early 99 on rock auto for $45. Can get part numbers and check Amazon and local parts stores to. I'd spend that much before I fooled with changing bushings in stock one.
Old Feb 14, 2024 | 05:25 AM
Jamon Norton
I thought moog parts had went downhill quality wise?
Old Feb 14, 2024 | 08:52 AM
Tpayne621's Avatar
Tpayne621
I wouldn't run moog ball joints and stuff that's a big job to change and expensive to do. But something cheap and easy to change like a track bar I'd give it a go for 40 bucks and 30 minute of time. There is also lot of other brands in there around same price point if you don't want a moog.
Old Feb 14, 2024 | 10:28 AM
Jamon Norton
Very true just the bushings are about the same price
soundquest
1997 - 2003 F150
Nov 23, 2021 07:39 AM
CNC
Sep 15, 2015 04:54 PM
JeffHann74
Oct 25, 2010 01:24 PM
DIANE THERRIEN
Oct 16, 2010 06:51 PM
BillyBob69
16
Sep 19, 2009 11:20 PM
