Sponsored by: Real Truck
Can't take ignition cyclinder out
Old Feb 10, 2024 | 07:26 PM
Monty13's Avatar
Monty13
2nd Gear
Looks like someone tried to steal the truck, 2002 F250. The key hole on the door was punched in and the ignition has marks on it and the black cap on the ignition that you use to turn the key was on the floor.
I tried to start the truck but the key won't twist. After about 15 minutes of wiggling, the key turned and it starts. I figured I should change the cylinder so I can start it when I need it to and I'm not sitting there wiggling and hoping it would start.
I cannot take the ignition cyclinder out. I can verify that the little ball underneath the steering column is pushed in (using a screw driver), the cyclinder moves out just a little bit (enough to notice) but stops there.
The key is in the ON position, I am wiggling it, even used a plier for more force but wouldn't budge anymore.
Any ideas? It's right now soaked in wd40.
Old Feb 12, 2024 | 09:29 AM
nydiver's Avatar
nydiver
You got the right idea, I think its in off position you push in the detent on the bottom, which I don't think you can reach with the column cowl on, but you push it in and turn the key 1 click forward and then it should pull outward. Remove the cowl to be sure you're pushing in the right part.
JBrumfield
1997 - 2003 F150
Jun 27, 2021 02:26 PM
RyanG21
Aug 12, 2017 08:06 PM
86f250xl
Large Truck
Apr 2, 2015 06:15 AM
bassproguy07
Feb 3, 2007 02:40 AM
BoneSS
Jul 10, 2004 03:57 PM
