Chisel the pistons out, since block is garbage only good parts would be the crankshaft and rods
That is a solid idea. I had pondered trying to cut the block. Your way seems easier.
I did grab some new parts for my trucks engine. This lip spacer allows the use of the filter Ford started using on the SDs. Filters the oil before it goes to the hpop. Also my oil cap was starting g to feel brittle.
