6.2L V8 Discuss the 6.2L V8
2018 F250 6.2 engine codes
Old Feb 10, 2024 | 07:03 AM
FirstPriority's Avatar
FirstPriority
4wd Low
Hey Peeps... Looking for some help.
I am getting these codes :
P0316
P2097
P2099
Engine is stock with a SB cold air intake. Exhaust is Stainless Works headers with high flow cats. I also installed the bongs for the O2 sensors post cat. And a Flowmaster CAT back dual exhaust which I dont think matters here.
At first on long trips... 2+ hours on the highway would cause the check engine light to come on on next startup. Throwing codes 2097 and 2099. Then intermittently I have began to see the P0316. Now its gotten to the point over the last months were any highway drive seems to be throwing the codes and the 316 code is seen more at startup. When the code is thrown the truck smells like its running richer and the idle is rougher seeming to almost shut down at or below 500 rpm.
We have just. finished a smoke test and found no exhaust leaks from the cats forward. All plugs have been changed with motorcraft platinum. truck has 108k miles.
Who's got ideas for me?
Old Feb 11, 2024 | 07:55 AM
railroader's Avatar
railroader
Don't know enough, other than you posted some codes that refer to fuel trim. Might be a camshaft timing sensor, or O2 sensor(s) maybe. I'm sure someone else will have more clues. If you have an old laptop laying around, get FORSCAN on it. You might be able to dig a little deeper and hopefully it isn't something internal.
Old Feb 11, 2024 | 08:22 AM
FirstPriority
4wd Low
Thank you railroader
Old Jul 8, 2024 | 01:59 PM
Campo173's Avatar
Campo173
3rd Gear
Any update to the problems your are encountering. My 2018 6.2 is doing the same thing as far as the P2099 after about 2-3 of driving on long trips. Usually towing.
00Stratos
2009 - 2014 F150
Jun 3, 2023 06:52 AM
tattooed_yoshi
May 20, 2013 03:37 PM
BULLETPROOF4.9
1978 - 1996 Big Bronco
Apr 3, 2009 02:41 PM
goalieman1830
Nov 28, 2006 12:12 PM
freddye
Oct 28, 2005 01:06 AM
