engine light codes
Old Nov 27, 2006 | 02:59 PM
goalieman1830's Avatar
goalieman1830
engine light codes
hey my check engine light came on the other day so i got the codes to tell me the issue and now i need to figure out how to fix\what they mean. the first code i got was p071 bank one which means system to lean....what does that mean. And the next code i got was p0420 bank 1 which reads catalyst efficiency below threshhold. Lastly i got a p0174 which means system to lean. any ideas what i need to be looking at?
Old Nov 27, 2006 | 06:06 PM
SUPER6's Avatar
SUPER6
Lean Codes Usually Mean A Vacuum Leak. The Cat Code Probably Means The Cat Is Bad. But Depending On How Bad The Vacuum Leak Is, Depends On How Hard The Cat Has To Work. Fix The Lean Codes And See If That Fixes The Cat Problem.
Old Nov 28, 2006 | 12:12 PM
PETE PETERMAN's Avatar
PETE PETERMAN
Autozone.com Has All Of The Codes And Explanations On The Codes.
WhyFord
163
Feb 17, 2017 07:49 PM
jmccracken1214
Sep 21, 2016 07:50 PM
msradio
Jan 22, 2013 08:16 AM
Schlava
6.7L Power Stroke Diesel
Oct 10, 2012 06:32 PM
mdjohnson
1997 - 2003 F150
Sep 13, 2006 07:20 AM
